Suspension about to buy some Megan coilovers...got some questions
Old Aug 27, 2008 | 07:30 AM
  #51
Rally@StanceDesign's Avatar
Rally@StanceDesign
Originally Posted by pimpedout97x
TUV rates the fronts at 70mm and rears at 65mm..
The VW ones are TUV rated to 65mm and still bottom out too
Old Aug 27, 2008 | 07:42 AM
  #52
MiniStupidfun's Avatar
MiniStupidfun
Ah! so If I were to purchase the megans. Would I be able to lower them to were there would be no visable gap in the wheel well? I dont want to have them tucked, just no gap.
Old Aug 27, 2008 | 08:09 AM
  #53
MidniteCoop's Avatar
MidniteCoop
What's up Dan,
I figured I'd drop these in for reference, both Dopamine and I are running the original V.1 megans, I got mine from Rally.
If you can buy an old set you'd be good.
You can also get a new set, and change up the springs to a shorter version to achieve the same drop...
Dope has his wheels tucked so there is really no gap and I can fit 1 finger between the top of the wheel and the fenders.
so there is really low wheel gap...
Depending on your wheel size you could pull of either..
Old Aug 27, 2008 | 08:20 AM
  #54
MiniStupidfun
Whats good man,
So how do I find the first version?
Old Aug 27, 2008 | 08:26 AM
  #55
pimpedout97x's Avatar
pimpedout97x
search for a used set.
i want to tuck rim on mine.
Old Aug 27, 2008 | 08:38 AM
  #56
Rally@StanceDesign
Hahaha front and back? Good luck turning That may be hard to achieve with any of the coilovers out there. Tucking rim, even on 18's will be pretty hard to achieve.
I've got airride and I'd tuck 18" rim but it's a really far drop to get it to tuck that much.
What size tires are you running. I'm sure that the V3 megans would be able to get rid of the gap if you don't want to tuck. That doesnt require much of a drop unless you've got tiny tires
Old Aug 27, 2008 | 08:43 AM
  #57
MiniStupidfun
215/45R16
Old Aug 27, 2008 | 08:56 AM
  #58
Rally@StanceDesign
The Megan V3's should easily eliminate any gap then. Even V2's could eliminate gap but couldn't tuck.....and the V3's can go lower than the V2's so you should be fine
Old Aug 27, 2008 | 08:59 AM
  #59
MiniStupidfun
Cool! So now where to buy?? The best deal I have seen is 850 shipped.
Old Aug 27, 2008 | 10:04 AM
  #60
littlehandegan's Avatar
littlehandegan
Coordinator :: Low Country MINIs
So to get the V3 megans to go as low you have to get new springs? Where do you find these sire?
Old Aug 27, 2008 | 10:06 AM
  #61
MidniteCoop
I know Megan offers shorter springs, The V3's can be ordered with them..
Or, some have run eibach springs instead, in a shorter size.
Old Aug 27, 2008 | 10:39 AM
  #62
AutoXCooper.com's Avatar
AutoXCooper.com
Please email me the link for that price and I'll see if I can match it. info@autoxcooper.com
Old Aug 27, 2008 | 10:41 AM
  #63
littlehandegan
Autoxcooper can you get the megans with the old springs?
Old Aug 27, 2008 | 10:46 AM
  #64
MiniStupidfun
Autox
could you get the megans with an older style spring?
Old Aug 27, 2008 | 10:48 AM
  #65
AutoXCooper.com
Autox
Yes I can, it's $75.00 more for the front spring exchange by Megan.
Old Aug 27, 2008 | 10:51 AM
  #66
pimpedout97x
what do you have airride on??? the MINI??? if so, lemme see pics!
i meant tuck tire, i didnt realize i typed "rim" lol.
basically i wanna sit like DOPAMINE
Old Aug 27, 2008 | 10:56 AM
  #67
pimpedout97x
is there any bagged MINIs out there anyways?
Old Aug 27, 2008 | 12:39 PM
  #68
meb's Avatar
meb
you can order from Eibach
Old Aug 27, 2008 | 01:48 PM
  #69
Rally@StanceDesign
yah....my Clubman is on bags. Check my buildup thread over on M|U under 'the lineup'
Old Aug 27, 2008 | 01:49 PM
  #70
pimpedout97x
ok cool. disregaurd the PM i just sent you then LOL
Old Aug 27, 2008 | 02:06 PM
  #71
pimpedout97x
i dont see it...unless the pics arent showing up for some reason
Old Aug 27, 2008 | 03:01 PM
  #72
littlehandegan
You gotta search through the last few pages, there in there ...Now if only i had some RM's with some Dunlops
Old Aug 27, 2008 | 03:12 PM
  #73
MiniStupidfun
http://waymotorworks.com/product.php...6&cat=0&page=1
Old Aug 27, 2008 | 03:55 PM
  #74
AutoXCooper.com
yep, Way and I sell them for the same $850 plus $50 shipping and if you want the lower front springs it's another $75. Unless there's something I'm missing. Which is the lowest lowest price Megan allows.
Old Aug 28, 2008 | 03:52 AM
  #75
MiniStupidfun
you guys will be hearing from me tomarrow
Hippiehobbit267
Dec 3, 2019 04:22 PM
Da_jesus
Aug 25, 2015 04:20 PM
DiGiPiMP
Aug 24, 2015 11:04 AM
WestfaliaR
Aug 19, 2015 08:01 AM
nomar116
Aug 10, 2015 11:24 PM
