Suspension Coilovers: The Agony and The Ecstasy
Old Jul 20, 2008 | 07:31 AM
  #26
cliff@coasttocoastusa's Avatar
Former Sponsor
Originally Posted by hemiheaded18
The more and more I look at coilovers, the more and more it seems like a more budget concious choice. The lousy part being any of the cheaper coilovers don't have their own camber plates and I'm not crazy about reusing old parts on a new $1000+ suspension. Edit: Do either of the H&R kits come with camber plates or is it limited to top of the line Cross and lower end Megans?
Its been discussed but the BC's setup is very similar to the cross's with built in front camber plates. For the price the bc's are fantastic.
Old Jul 20, 2008 | 10:29 AM
  #27
oxtox's Avatar
oxtox
bc's come with fully adjustable camber plates....and i believe the megans do as well
Old Jul 20, 2008 | 10:33 AM
  #28
AutoXCooper.com's Avatar
AutoXCooper.com
Yes the Megan's do come with camber plates, NEW rear top hats and rear damper adjustment cables. They are priced right, they are not "low end" or "cheap".
Old Jul 20, 2008 | 12:12 PM
  #29
hemiheaded18's Avatar
hemiheaded18
I've been in 2 cars with Megan's and hated every minute of both of them. Just my $.02 them. But how is the ride compared to stock with the BC's? I keep hearing of how the pricier setups not only handle better but also have a softer ride and this sounds truly appealing.
Old Jul 20, 2008 | 12:37 PM
  #30
minim8o's Avatar
minim8o
Originally Posted by cliff@coasttocoastusa
My statement may have been a bit bold. A street oriented car will vary in weight on an almost daily basic depending on cargo, passengers etc. Though the car may not be completely asymmetrical, with a good alignment and installation I see no real world issues for a daily driven street car.
I 100% agree. When I had Penske 8100s mounted on my current car and separate adjustable spring perches, I insisted on corner balancing.
http://public.fotki.com/m8o/kar_kraz.../dscn0028.html
It was a total waste of money. It could not compare with:
a) finding the proper ride height front & back as that affects the suspension geometry & damper "sweet spot".
b) suitable caster & camber angles
c) the most importantly, the proper toe angle in front, and even more importantly, proper toe angle in the rear. (possible as I replaced most all the links w/adjustable ones w/hiem joints)
....that was worth the money in cost of trial & error experimentation by the speed shop doing the installs & alignment(s) ... I believe 6 in total before i found the right combos. This does not yield a 4 corner balanced setup, but does yield an extremely responsive and balanced suspension under extreme direction changes.
I will add, I'm not sure I have settled on the right set of spring rates front & rear. Presently @ 950ft-lb front & 600 ft-lb rear. I think I need to go to 650 rear or 700... So there's that too to consider.
Old Jul 20, 2008 | 01:33 PM
  #31
AutoXCooper.com
I have found the issue of ride quality to be subjective. I also know there are many more Megan 1.0 out there then the latest updated 3.0 systems. The current system when run within reason works very well on all counts. Once a week someone will call me about Coilovers and after talking with them and learning what their goals are with a MINI I will NOT sell Megan's or any coilover to them. I'm also a Cross Dealer, but I have found any coilover lowered all the way down running 45 or smaller side walls will have less then great rides.
One of the big things I try to help my customers understand is "lowering" a MINI is not the only way to get better handling and most of the time cost more in cash and ride then you gain.
For bling owners with lot's of cash, buy the Cross or M7 setup, slam it and roll. Many of my customers are working within a budget and have found the Megan's and BC's to work very well within that budget. Many of them have also found a set of TSW Springs and IE Camber Plates work well and save them even more money.
Old Jul 20, 2008 | 05:27 PM
  #32
hemiheaded18
I like the idea of coilovers but am not crazy about the thought of drilling a few holes in the back of hatch area to accomodate the adjuster cables. I know you can set them outside of the car before install but not having the adjustability kills the main point behind having them in the first place. Without going ***** to the wall *Cross*, is there any options that allow for adjustment on the bottom of the coilover unit?
Old Jul 20, 2008 | 07:06 PM
  #33
AutoXCooper.com
Yes, M7 coilovers offer rear damper adjustment from the bottom.
Old Jul 21, 2008 | 07:30 AM
  #34
Dr Obnxs's Avatar
Dr Obnxs
LEDAs do as well
you just lie on the ground and twist the ****....
I'm sure others do as well....
Matt
Old Jul 21, 2008 | 08:04 AM
  #35
ChrisMCS04's Avatar
ChrisMCS04
Peace Keeper
Originally Posted by Fracky
I'm near ready to purchase new suspension as well & I'm up on all the products out there. My/our car is mostly for show & the occasional romp through the mountains. I guess I'm looking for something with a wicked stance, comfort level for my wife, well-balanced for the kind of driving I do, but able to be pushed to the limit should I choose to do that.
I really appreciated ChrisMCS04's ultimate coilover thread because I could get an idea of what the installed product looked like. I've decided to go with either TSW AST/Swift SA or KW v.2's (for a couple reasons), but I haven't seen any feedback from the people who have these setups. When I saw the title of the thread "The Agony and the Ecstasy", I laughed cuz' I keep having that thought. On that note...does anyone have feedback to these setups?
Thanks for the compliment I still have to sort through that thread that I made to see what updates I need to make and if I am missing anything.
Do you think I have missed anything yet? If anyone wants to go to my thread and leave me some feedback or advise I would love it
OK, thread jack over
P.S. Fracky if you would like to expand on your choices in that thread I would love to know why you are looking at those options.
Old Jul 22, 2008 | 05:45 AM
  #36
ChrisMCS04's Avatar
ChrisMCS04
Peace Keeper
Don't Bilstein PSS9's have lower adjustments as well? But those are more than Cross's.
Old Jul 22, 2008 | 05:58 AM
  #37
meb's Avatar
meb
"Between Agony and Ecstasy" is a great movie!
If you are beginning, camber plates and a sway bar is all you need. If you are a good driver, you can accomplish a lot with these two mods. New springs and dampers can really complicate a set up...
Old Jul 22, 2008 | 09:41 PM
  #38
Ubercooper968's Avatar
Ubercooper968
I just replaced my H&R for for Tein basics and the car looks a whole lot better, more adjustments and didnt need camber plates, perfect fit. I can barley put my hand between the fender and the tire.
Old Jul 23, 2008 | 10:25 AM
  #39
heyduard's Avatar
heyduard
... is there any options that allow for adjustment on the bottom of the coilover unit?
in addition to the others mentioned, spax has the adjustment near the bottom of the damper body.
The more adjustability, the more agony.
Old Jul 23, 2008 | 03:05 PM
  #40
RedSkunk's Avatar
RedSkunk
Originally Posted by ltphoto
A little bit of autoX. Definitely no serious track use. And want to be able to agressively run the curves in the mountains around here on without jarring my kidney's out of place. I already have an Alta 19mm rear sway bar on the stiffest setting. I have H&R sport springs. They are a little better than stock suspension, but not overly so. Dropping the car is not important other than what it contributes to handling.
The BCs have definitely been a big improvement for autox, coming from lowering springs + Koni Yellows. They are also, OVERALL, better riding. They crash over jarring pavement, but... So did the springs+Yellows, and springs+stock, and all stock. I'm very suspicious of anyone who says they've got a suspension set-up that delivers both performance and a smooth ride. ("better ride than stock" = red flag for me by this point, but maybe I just don't remember how it felt stock..)
For the money, tremendous deal. I'd say you're looking at decreasing gains going for something like the CROSS for 2x the $$$. Might be better in all aspects (no personal experience). Surely not 2x the performance. "IMHO"
edit: oh, and don't worry about the whole "drilling holes through your car" thing. It feels wrong at first, but out of sight, out of mind. Being able to adjust all four corners rocks.
Old Jul 24, 2008 | 01:37 AM
  #41
rjtrout2000's Avatar
rjtrout2000
How about a nice set of coils? You could autox your car on M7 or TSW springs and see good to great results doing so. Just a thought
Old Jul 24, 2008 | 04:17 AM
  #42
hemiheaded18
Matt
Who is a good, reliable source for Leda's?
Old Jul 24, 2008 | 05:44 AM
  #43
ChrisMCS04's Avatar
ChrisMCS04
Peace Keeper
m7 and mini-madness both used to sell LEDA and I know madness still has them on their site
They are $$$$$$$ though, just know that.
Old Jul 24, 2008 | 10:16 AM
  #44
RedSkunk's Avatar
RedSkunk
Didn't Lucky Dog Garage and / or DMH sell Ledas? They're east coast, NJ there abouts.
Old Jul 24, 2008 | 10:31 AM
  #45
minim8o's Avatar
minim8o
If you have double adjustable shocks you can set compression to soft on the road and rebound firmer to counteract the firmer springs. ...works for me w/my C43/55 and Penske 8100 dampers to give a much more compliant ride that the firmly valved stock Blistenes the car comes with, yet quickly firms up on turn-in after slight motion and taking a seat ... cost of entry, don't ask if you don't know already...
Old Jul 24, 2008 | 01:27 PM
  #46
RedSkunk's Avatar
RedSkunk
Originally Posted by minim8o
If you have double adjustable shocks ... more compliant ride that the firmly valved stock Blistenes the car comes with, yet quickly firms up on turn-in after slight motion and taking a seat
Sounds like the same compromise you get from progressive springs, which everyone is always complaining about..
Old Jul 24, 2008 | 01:39 PM
  #47
Dr Obnxs's Avatar
Dr Obnxs
Also Racers Edge in NJ I think...
you can google them. Also, they sell the different spring rates, and also do rebuilds. Karl Poetl (I think that's the spelling) is a good guy and they really know suspensions, but mostly for Porsche. TSW was selling Ledas as well. Yeah, they're not cheap, but after you rebuild them once or twice it works out to a lower cost of ownership than those that can't be rebuilt.
Matt
Old Jul 24, 2008 | 02:48 PM
  #48
hemiheaded18
MC2 had an article some time ago about these guys:
http://www.tcklineracing.com/
The article was an R56 with a TCK Koni coilover setup with adjustable camber plates. Any knowledge of them or the product? I looked on their site and found nothing but as we all know, this doesn't mean it doesn't exist.
Old Jul 24, 2008 | 05:41 PM
  #49
hemiheaded18
Another question was posed to me on another MINI forum. Are the new end links with the Cross set-up adjustable like the TSW links?
Old Jul 24, 2008 | 06:08 PM
  #50
minim8o's Avatar
minim8o
So you're saying race car's shouldn't use double adjustable dampers minimum, if not triple or quadruple adjustable...? no, progressive gives a non-linear response to motion in both directions, making the ability for the damper to control that motion in a consistent fashion at all levels of spring compression through the suspension travel an impossibility... Double adjustable dampers allows for the behavior to change between compression and rebound; with linear springs used, a linear controlled motion in both directions... I'm just saying you can set it up to be faster on compression than rebound which is great for a bumpy street setup. I run Eibach 2.5" race springs, 950lb/in front / 600lb/in rear.
Click here then click the link in that post to the Technical manual, and read the section on damper theory (the pages I point out in that post).
Last edited by minim8o; Jul 24, 2008 at 06:51 PM. Reason: correct spring rate unit -- thanx Dr Obnxs
