Suspension JIC/Cross Coilovers installed!
Old Mar 25, 2008 | 11:01 AM
  #26
Guest's Avatar
Guest
Originally Posted by SteveS
https://www.northamericanmotoring.co...r_profile2.JPG
Here is my setup. Danny likes the front way low and I had him bump it up about 3/4 inch. Still drags the plastic just a little here and there.
I would post the picture here but I do not know how to do it.
If you e-mail me the pictures I can do it for you.
Old Mar 25, 2008 | 11:02 AM
  #27
Guest's Avatar
Guest
Originally Posted by lttletimmy
Here are the pictures, as promised. This is on my track wheels, 17x7 RPF1's.
Lookin good
Old Mar 25, 2008 | 02:51 PM
  #28
lttletimmy's Avatar
lttletimmy
Thanks!
Old Mar 27, 2008 | 02:38 PM
  #29
jpavlo's Avatar
jpavlo
I plan on installing my Cross coilovers next week. The installation instructions are a bit sparse. I'm concerned about installing the rear adjuster cables so there is no binding or pinching. Any advice? Thanks
Old Mar 27, 2008 | 05:34 PM
  #30
Ryephile's Avatar
Ryephile
If you're in need of setup instructions, get a hold of the retailer you bought them from; they should have solid advice regarding damper body lengths, preload, starting points for damper firmness, and camber settings.
Regarding the rear adjuster, make a mark with a sharpie where the center of the shock body shaft is while at ride height with the axis extended upwards to the chassis. It is on a bit offset versus where the shock mounts to the chassis. Drill a pilot hole about a 1/2", but plan on drilling out either a slot or a big hole to allow the cable to clear the chassis over the entire suspension travel range. I wish I made a template when I did it on my car, as it would be helpful for others [MINI still in winter storage, grr]. Be patient, measure and mark twice and cut once!
Old Mar 27, 2008 | 05:48 PM
  #31
newbs49's Avatar
newbs49
Joe
Call Danny at minicorsa per Jan. He has done a few of these and does the installs for Jan. Let me know when you get these installed. Also you could call Jan, who will get you intouch with his buddy at Cross.
Old Mar 27, 2008 | 06:39 PM
  #32
SteveS's Avatar
SteveS
Danny installed mine but did not install the adjusters.
COR BLMY wrote instructions which should explain and show what to do. The coilovers are similar
https://www.northamericanmotoring.co...ight=coilovers
I hAven't installed mine but when time allows maybe I'll try. I just hate cutting into the car and it appears there is no alternative.
Old Mar 27, 2008 | 08:32 PM
  #33
Ryephile's Avatar
Ryephile
... I just hate cutting into the car and it appears there is no alternative.
You don't have to cut a hole in the car. You can take the long way and remove the shock every time you want to make an adjustment. *flashback to adjusting the Koni Yellows*
Old Mar 27, 2008 | 09:32 PM
  #34
lttletimmy's Avatar
lttletimmy
the north American president of JIC didn't even install the adjusters in his R56, he said there's too much in he way (especially with hi fi and that amp there). If you don't install the adjusters the installation is extremely easy, just replace the stock shock assemblies and front endlinks with the jic units.
Old Mar 28, 2008 | 01:48 PM
  #35
jpavlo's Avatar
jpavlo
Thanks for the info.. Since I do track days I like the ability to make quick adjustments. I don't mind making a hole or two. Checked out COR BLMY's excellent write up and have Jan & Danny's phone #s close by.
Old Apr 13, 2008 | 08:38 AM
  #36
earlgrey's Avatar
earlgrey
Hey where to get Cross coilover for R56, any shop to recommend? Must be those who's willing to ship overseas..
Old Apr 13, 2008 | 10:24 AM
  #37
SlowB00st's Avatar
SlowB00st
http://www.revolutionmini.com/
Old Apr 13, 2008 | 11:39 AM
  #38
jpavlo's Avatar
jpavlo
+1 Contact Jan @ RMW
Old Apr 16, 2008 | 02:08 PM
  #39
MotorMouth's Avatar
MotorMouth
Do these coilovers come with camber adjustment or you gotta buy something seperate?
Old Apr 16, 2008 | 02:17 PM
  #40
jpavlo's Avatar
jpavlo
Yes, they come w/ camber plates
JIC/Cross Coilovers installed!-cross-coilover-1.jpg
Old Apr 16, 2008 | 04:01 PM
  #41
lttletimmy's Avatar
lttletimmy
After tracking the car this last weekend (and the car performed spectacularly!) I'm going to try installing the rear adjustment cables when I get a chance. It was just way too much of a pain to remove the rear shock to make an adjustment. Other than that, it was great. Posted times that would haveput me roughly midpack of the lotus challenge series that was running the same weekend, so I felt pretty satisfied
Old Apr 16, 2008 | 04:32 PM
  #42
MotorMouth's Avatar
MotorMouth
Attachment 31304
Thanks! guess I need to call Jan!
edit:
Talked to Jan and I'm on the list for the next shipment.
Old Apr 16, 2008 | 10:01 PM
  #43
lttletimmy's Avatar
lttletimmy
congrats! You'll love 'em, and you definitely picked the right person to buy them from
Old May 3, 2008 | 04:18 PM
  #44
lttletimmy's Avatar
lttletimmy
I drilled the holes for the rear cable adjusters today, it was a pretty simple, straight-forward job. No problems at all, not sure why they recommend not doing it for the R56. The only problem is I over tightened the lower bolt connecting the coilovers to the hub assembly and can't find a thread repair kit in the right size!
Guess I'll be waiting a while to drive her again...
Old May 20, 2008 | 05:13 PM
  #45
MotorMouth's Avatar
MotorMouth
My wallet is a bit emptier now. The coilovers are supposed to ship today!
Old May 20, 2008 | 07:42 PM
  #46
th3118's Avatar
th3118
Coordinator :: Dynamic MiNi Collective
Mine too! Can't wait.
Old May 22, 2008 | 02:49 PM
  #47
MotorMouth's Avatar
MotorMouth
In transit. Delivery by 5pm tomorrow. I don't know when I'll get to install them though. Maybe Tuesday.
Old May 22, 2008 | 03:00 PM
  #48
Bhatch's Avatar
Bhatch
Anyone know what the Max hight of the setup is? can i bring it back to stock height and bring it back down again?
thanks.
Old May 22, 2008 | 04:06 PM
  #49
MotorMouth's Avatar
MotorMouth
The desciption says it lowers from a range of .5" to 2.5" It doesn't say anything about stock height or higher.
It'd be nice to raise up and do some offroading haha.
Old May 22, 2008 | 04:18 PM
  #50
BobinPhilly's Avatar
BobinPhilly
Have you added adjustable lower control arms?
Have any of you who've installed Cross coilovers also installed adjustable rear lower control arms to help in setting the rear camber you want?
If so, whose control arms have you installed, and why that brand?
