Suspension TSW R56 springs - coming soon
Old Oct 31, 2008 | 01:11 PM
  #151
santiage's Avatar
santiage
Originally Posted by AutoXCooper.com
Based on a review of www.realoem.com it looks like the rear springs in the R55 Clubman are different then the R56, I would bet they are a higher spring rate to allow for more load in the wagon. Also know that the Rear R52 OEM Springs are a higher rate then the R53 or R50. While the TSW springs may "fit" an R55 I would bet the rear would sit lower on an R55 than R56 and would limit the load of the R55 making the "space" less useful with heavy loads. I know a few R52 owners running TSW Springs without issue, but they also don't have the space to carry much more weight in the back. Just some things to think about.
I'm confused, do they fit the R55 or not?
Old Oct 31, 2008 | 03:44 PM
  #152
SK8BRD's Avatar
SK8BRD
Your VIN is required to know which OEM springs are installed. More than likely the longer your option list the longer the spring will be so that the same ride height is maintained with cars of differing weights.
Old Oct 31, 2008 | 03:46 PM
  #153
SK8BRD's Avatar
SK8BRD
Originally Posted by txwerks
Production springs are arriving today... We'll be doing a final fitment tomorrow @ 1PM and I'll post pics immediately afterwards. Assuming the final production version meets specs, these will be up tomorrow evening for purchase...
Trick or Treat!
Old Oct 31, 2008 | 05:11 PM
  #154
txwerks's Avatar
txwerks
As soon as we can get a clubbie over here for a test mule, we'll letcha know!
Speaking of - anyone in the D/FW have a clubbie that they want to let us test springs on?
Old Oct 31, 2008 | 06:43 PM
  #155
gnatster's Avatar
gnatster
Scott, I'm sure there will be a few clubbies at the next meeting. To get you and Jeff to come it's being held a the Rahr Brewery with free beer served.
Old Nov 1, 2008 | 02:23 PM
  #156
gnatster's Avatar
gnatster
Just got back from taking shots of the install for the upcoming product review in the Alliance Magazine (Look for it Dec 19).
This is just off the jackstands. Have not fully settled as of yet.
Old Nov 1, 2008 | 02:39 PM
  #157
AutoXCooper.com's Avatar
AutoXCooper.com
Please do not judge the look of this MINI with TSW springs based on that pic. Thanks Dustin
Old Nov 1, 2008 | 02:42 PM
  #158
txwerks's Avatar
txwerks
And, we're proud to annouce... we're done.
We just finished installing the production version of the R56 springs, and we can now say that they are READY TO SHIP!
Drop is right around 1" front and 3/4" rear...
Linear rate, cold wound... 225 lb/in front and 269 lb/in rear. Unlike the R50/R53 springs which are 200 lb/in all around, MINI's changes to the R56 platform necessitated different rates in the front and back. OEM rates are "freakin' coat hangers" (~150 lb/in) in the front and 212 lb/in rear.
You'd think that bumping the OEM spring rates would result in a harsher ride, wouldn't you? Welp, based on the dyno plots of the OEM struts and shocks, the R56 is woefully undersprung from the factory - same as the R50/R53 platform. The ride on our R56 TSW springs is BETTER than OEM by a long shot, with better cornering, and a more settled car in the twisties.
Our springs offer a stellar ride, great looks, and KILLER performance with all OEM struts and OEM-style replacements (e.g. Koni Yellows). Our test car picked up 5 MPH in average speed PER LAP at Eagles Canyon!!!
MSRP is $229.
http://www.txwerks.com/servlet/Detail?no=243
Old Nov 1, 2008 | 02:46 PM
  #159
txwerks's Avatar
txwerks
Driving around for 15 minutes settled the fronts in nicely... After 200-300 miles, we expect the fronts and rears to settle in another 1/4" - 3/8" - netting the original results we were after of a 3/4" drop in the rear and 1" drop in the front. So, no worries on the picture - it was just the first shot.
Against OEM ride height right off the jackstands, the difference is noticeable. It was even more noticeable after a 15 minute drive.
Oh, and this is a Cooper on OEM 16" RFT's...
Suffice to say, this is going to net out just as we planned...
Old Nov 1, 2008 | 02:55 PM
  #160
txwerks's Avatar
txwerks
One other tidbit of information...
With the alignment pins yanked on the upper strut mounts in the front and shoved all the way inboard, we measured -1.5 degrees of negative camber up front - not bad! Turn-in is markedly better...
We'll be gettin' a clubbie over for some measurements ASAP - so, stay tuned clubbie fans!
Old Nov 1, 2008 | 03:50 PM
  #161
melman8r's Avatar
melman8r
Ordered. Thanks. Ship them quick PLEASEEEEEE.
Old Nov 1, 2008 | 04:32 PM
  #162
old81's Avatar
old81
M6
We shall see how they settle on my 07 MCSa with the base suspension.
Ordered a set, I hope I see them in a week or so.
Old Nov 1, 2008 | 05:22 PM
  #163
SK8BRD's Avatar
SK8BRD
You calling my baby ugly?
But seriously folks. I ran the prototypes for two months and loved the ride, if not the look. I didn't expect the ride to get better with the production TSW springs, but it did. 50 miles on the car since the install this afternoon. I'm lovin the new ride quality.
Old Nov 1, 2008 | 06:34 PM
  #164
old81's Avatar
old81
M6
Did you start with a base suspension or the MINI sport suspension?
I guess I will know once I get my set and get them installed and a good alignment.
Are you going to install the camber plates or do you have a set of nice prototypes, already?
Post some more pictures after the Cooper settles.
Thanks,
Don
Old Nov 1, 2008 | 08:23 PM
  #165
LAcooperS's Avatar
LAcooperS
Wooo Hooo Finally a cure for my H&R Blue's... paid weeks ago, so hopefully they will arive quick and I will have em installed by the end of next week... Asuming they ship on monday ... Hint ... Hint... Please!!!
Thanks to TSW... for takeing their time and doing it right!
Old Nov 2, 2008 | 06:12 AM
  #166
SK8BRD's Avatar
SK8BRD
Thanks,
Don
I have the sports suspension, but next to other MINIs it is the same ride height. I've pulled the alignment pin out of the strut towers and shoved them inward. After I put some miles on the car I'll have it aligned and we'll see what I can get.
Old Nov 2, 2008 | 07:09 AM
  #167
e30r56's Avatar
e30r56
I can't wait to see settled pics of this and more feedback on ride quality.
Old Nov 2, 2008 | 07:46 AM
  #168
txwerks's Avatar
txwerks
All orders will ship Monday... Thanks to all for being so patient, but we had to get it right.
The spring rates are designed to work with the regular, sport and JCW struts (which have slightly different dyno plots, but not a lot of difference).
R56 camber plates are up next... And, Mr. SK8BRD will get the prototype set, since he is an autocross and track junkie (like us).
Mr. SK8BRD has been riding around on the 2nd prototype set for a couple thousand miles and done some autocrossing and track events on them. The production springs do feel "even better" to our well calibrated butts, too.
Old Nov 2, 2008 | 07:47 AM
  #169
txwerks's Avatar
txwerks
That is a cherry e30 ya got there!!! Our's needs some paint to get it back into shape...
Old Nov 2, 2008 | 04:57 PM
  #170
e30r56's Avatar
e30r56
Thank you. It's my pride and joy for which the Mini is the daily driver for. I actually just re-did the suspension for all 5-lug and Ground Control coilovers. I also have a s50 engine in the works for it. For more pics: http://smg.photobucket.com/albums/v2...eier/My%20Car/ . Also, check out e30tech.com for virtually any question you have.
Old Nov 3, 2008 | 07:05 AM
  #171
txwerks's Avatar
txwerks
Feedback from another local who picked his springs up on Friday and installed them over the weekend (JCW car with regular (non-sport and non-JCW) suspension):
"I put the springs on today. You were not kidding, what a difference; it is
a whole new car. The car rides so much better. No more rear end squat on
tack off, and cornering is much flatter. Feels like the weight transfer in
corners is much more predictable, which was one of my biggest complaints
with the OEM springs."
Old Nov 3, 2008 | 07:08 AM
  #172
txwerks's Avatar
txwerks
If our M20 ever lets loose (325is), we're likely to go the s50 route, too. It's pretty flippin' easy nowadays!
We're still running on a Bilstein/H&R setup, as we haven't yet ruled out racing it in Spec e30. Otherwise, we'd be on AST coilovers.
I hate to say it (but not really), but our e30 KILLS the MINIs on our autocross courses...
Old Nov 3, 2008 | 08:15 AM
  #173
fbirch's Avatar
fbirch
Can you post a picture of the car after the ride height settles into it's final equilibrium position?
Old Nov 3, 2008 | 05:34 PM
  #174
SK8BRD's Avatar
SK8BRD
I sure will. It didn't get much action yesterday as I went to Texas Motor Speedway for the Sprint cup race with friends, but as of my commute I'm at 130 miles on the today. Wednesday I'll try parking next to a stock height R56 at Happy Hour for a side by side comparison.
Old Nov 3, 2008 | 05:38 PM
  #175
SK8BRD's Avatar
SK8BRD
Ditto on the even better! My car is looking better, I'm planning a photo-op with Missbehavin (another Chili Red R56 justa) for Wednesday.
