Suspension Trim shock tower metal for more camber?
Old Feb 5, 2008 | 06:48 AM
etalj's Avatar
etalj
Hi guys,
The metal at the top of the shock towers is interfering with my camber adjustment; even with coilovers, i can't get more than -2 deg. Is it ok to, and has anyone ever, trimmed back the metal to allow for more adjustment?
Thanks,
Elie
Old Feb 5, 2008 | 08:47 AM
meb's Avatar
meb
sure. I did this. Use a circle template and scribe an eccentric circle with a sharpy. Protect your winshiled and any other parts from molten pieces of metal being trown off a grinder...you should remove the struts, but if you can't or don't want to, use a plumber's rag - will not burn - to protect the top of the struts. Just be sure the grinder doesn't grab this cloth.
The molten pieces of metal will pit your windshield if you do not protect it.
Use an acid etching primer and then colored match your paint - done! figure a couple of hours.
Old Feb 5, 2008 | 12:26 PM
etalj's Avatar
etalj
thanks meb much appreciated. Will try to take a lot of care
Old Feb 11, 2008 | 06:36 PM
wrxmini's Avatar
wrxmini
i have -3.1 both sides with h-sport plates,no problem,the only trimming i done was on the side of the subframe down tubes,a little grinding on the edges to clear the steering knuckle,DO NOT GRIND THE WELD!
Old Feb 11, 2008 | 08:20 PM
Ryephile's Avatar
Ryephile
I elongated my strut tower holes too; works great and costs essentially nothing but time. Just be sparing with your hole elongation; the more material you remove the weaker the strut tower will get.
Old Feb 12, 2008 | 01:03 AM
etalj's Avatar
etalj
I got my suspension specialist to do this for me, cost me about US$30.
I'm running -2.5 deg front instead of my previous -2.
Thanks for all the help guys
DixonL2
Apr 13, 2021 08:05 AM
wesmc
R55 :: Clubman Talk (2008+)
Sep 28, 2015 12:07 PM
minners
Sep 21, 2015 09:26 PM
tag1260
Sep 2, 2015 07:42 PM
06R53
Aug 26, 2015 08:37 AM
