Suspension Springs - H&R vs. Mach V. Any opinions?
I agree with the 1" drop. I know my car's settled a bit and initially I was liking the 1 1/2" drop with the H&R's, but now an 1" would be just about right.
I guess it's either going with coilovers and being able to set the ride height or waiting to see what else comes out.
Okay. I give up. Gonna get some Mach V springs. They just look so damn good on the R56. So where do I send my money?
Turn in Concepts? Still have them for $199 with free shipping?
Fastmini? You guys make them, correct? Will you do free shipping too?
Are you both going to stand behind them equally (for 10 years)?
Although for $200, there's not a whole lot to lose. Unless the dealer gripes over the warranty if I have any suspension problems.
Any recommended spots for an alignment in eastern PA? What do I ask for and how much should I expect to pay?
Don't know why I waited so long to do this, but I might not install them till after the winter to see how the R56 does with a decent snowfall first. I have a 200' driveway which is dirt and gravel, so is a little uneven. And even when I do go over it with a snowblower, I don't go down to the surface, or gravel just keeps busting my shear pins on the blower (and those silly pins ain't cheap, but I am, so I often just use a bent nail instead of the pins. Very stupid idea.)
Jas.
Jas.
--Dan
Mach V
FastMINI.net
About realigning afterwards, read this guys' post #21 in the other lowering springs thread:
https://www.northamericanmotoring.co...d.php?t=116791
What I'm reading is that most people don't realign the car at all, which saves money too. Who cares if the RFs wear out a little sooner.
Springs are here!
One thing I noticed was instructions say lug bolts torque to 75ft lbs. I thought the spec for the R56 was over 100 with the change to 14mm bolts????
Actually, it's 104ft/lbs. In prior years it's 88. So in either case 75 seems too low, and makes one wonder where they got that figure. But then I know very few people that carry a torque wrench around when they change wheels. Seems a little ****.
Also, for those who have changed their springs: Is it necessary to have a spring compressor to install the new springs? Or will the 1.25" change allow me enough room to get the bolts started without one? I hate to be standing there with my struts apart and not be able to get them back together without a compressor (or Chuck Norris)
--Dan
Mach V
FastMINI.net
Then call us ****. We ALWAYS use a torque wrench for tightening wheel fasteners.
--Dan
Mach V
FastMINI.net
To me that's the way the R56 should look; an even space all around the arch. My only quandary is do I install mine now or wait till the snowy season has passed.
Dan, did you just buy a set of MC side markers and slip them on? I don't like my S markers, and wondered how much the swap would cost me.
Jascooper.... Thanks for starting this tread.
I never mind blazing a trail, however when someone else does it I don't mind following them. After searching and searching past postings I too ordered the Mach V Springs. All of Dan's responses were on the mark.
Let see now... the Cooper S is still on the boat.... and I've ordered non-run flat tires and springs. Yeah, I am normal.
Again, thanks Dan and Jascooper
Yeah.
Just this much!
--Dan
Mach V
FastMINI.net
--Dan
Mach V
FastMINI.net
smdmini
Oct 7, 2019 06:05 AM
massmini03
Sep 18, 2015 05:40 PM
atlantaorange
Sep 16, 2015 12:43 PM
