Suspension A study in rear adjustable control arms, with pics
Old Oct 22, 2008 | 07:51 AM
  #101
BlimeyCabrio's Avatar
BlimeyCabrio
The TSW arms are hot looking, too....
Though TSW needs to make more stuff in RED.
Old Oct 22, 2008 | 09:08 AM
  #102
JIMINNI's Avatar
JIMINNI
Originally Posted by MINIdriver85
I have the Alta V1 arms, and I think many of the squeaks I hear from the back come from them, at least one of them. I was thinking about changing them, but I want something that will grant me zero noise so maybe rubber will be better of heim joints, what do you think? Also, I've seen Alta has a v2 of their arms, has anyone tried them out and can tell me if they are noisy or not?
Not sure what version Alta arm I run, but they were making a horrendous sqeaking noise. Talked to my mechanic and called Alta. They are swapping out the heim joints for a revised one. They have been squeak free for months now The old joints were chrome colored, the new are black, might want to see what you have. Hope this helps .
Old Oct 22, 2008 | 09:29 AM
  #103
MINIdriver85's Avatar
MINIdriver85
Thanks, I've got the grey arms with chrome joints, I've seen that they now have a v2 that is red, these ones:
Honestly, I love Alta and I'd buy everything from them, lol, but with these arms I am a bit cautious, I've been living with this squeak for more than a year out of laziness, both mine and my mechanic's as I mentioned this to him asking him to grease my sway bar bushings (I thought the noise came from there) but he must have forgotten. Then I took the car to another mechanic to fit my custom header on July and he said it's probably coming from the control arms. Now I've to find a way to confirm this for sure and then the heim joint arms are going to be substituted with something that won't squeak for sure.
Old Oct 22, 2008 | 09:36 AM
  #104
JIMINNI's Avatar
JIMINNI
Ok, mine must be the version 2s, because they look just like these If you grab them and twist they should twist very smoothly, if they grab at all they are bad. Call Alta and get the new heim joints
Old Oct 22, 2008 | 09:44 AM
  #105
mcs22004's Avatar
mcs22004
Originally Posted by meb
I had two rear lower control arm failures and one was at about 90mph at Lime Rock and it wasn't fun. The rod end failure was accelerated by driving too many miles on bad public roads...and I didn't inspect them often enough at 250 miles a day of driving. The other was a a bushing designed in two halves as above...
That is the info for which I am looking. Could you elaborate? In each case, what were the brand of control arms that failed?
Old Oct 22, 2008 | 09:47 AM
  #106
mcs22004's Avatar
mcs22004
Originally Posted by AutoXCooper.com
I have researched for a year now and can't find any failure of that type of arm.
By "that type" do you mean TSW only?
Old Oct 22, 2008 | 10:01 AM
  #107
drmike@txwerks.com's Avatar
drmike@txwerks.com
In addition, for those designing and selling these, I also believe that the rear lower inner joint receives a majority of the load...meaning more than all of the other rear links...based upon observation, ie, what broke.
Thank you meb, this is hard-won information, and I appreciate your sharing it. It's good to know which joint is most-stressed.
Old Oct 22, 2008 | 11:49 AM
  #108
meb's Avatar
meb
142K miles so far...anything that I installed went thru hell for sure; the roads here or horrid, a few have been under construction for three years??? and the combination of 100 miles of highway and 100-150 miles of back road and I don't know how many track miles early on, placed a bunch of these components in particular light. Everything was left on for salt duty as well...
Old Oct 22, 2008 | 01:00 PM
  #109
AutoXCooper.com's Avatar
AutoXCooper.com
my bad, the type would be "center turnbuckle designs like Megan or H-sport" I have edited the other post too. Thanks for asking.
Old Oct 22, 2008 | 06:47 PM
  #110
mcs22004's Avatar
mcs22004
Thanks for the info.
I figured that if any would break, they would be the Bavarian Autosport arms, which look most like the Megans but come four to a pack for $299.00. However, I am getting the impression that all of these aftermarket arms are much stronger than the stock arms.
http://www.bavauto.com/lview.asp?img.../n62634bav.jpg
Old Jan 1, 2009 | 12:02 PM
  #111
FUEGO's Avatar
FUEGO
I've had the Megan arms (both upper and lower) on my '05 MCS for two years, ~24k miles, two seasons of AX and 8 DEs and never had a problem with them. Had the TSW control arms been available when I purchased them I would have gone that route instead. Everything I've purchased from TSW has been a solid and reliable product.
BTW - having the upper arms allowed me to decrease the rear track width just a smidge so that my 225-45-16 AX tires, and 215-45-17 street tires no longer rubbed without needing to dremel the inside lip of the rear fender flares.
W0TM8
Dec 19, 2019 07:50 AM
Toolman
Jan 20, 2016 06:50 AM
wkp1219
Nov 13, 2015 07:52 AM
Minibeagle
Aug 13, 2015 10:00 AM
OutMotoring
Aug 6, 2015 09:32 AM
