Suspension A study in rear adjustable control arms, with pics
Old Feb 22, 2008 | 09:33 PM
  #51
amg6975's Avatar
amg6975
Originally Posted by RedOut
No, I'm there now and they're still wrong.
It's simple guys, it really is. The z-axis is parralell to the center bar, the x and y are left and right and up and down looking at it from the top. The heim joints do not transmit any force in the x and y. It just doesn't happen. Period. Unless they are designed wrong, or they seize. Also the bearings could not be pressed in the center of the head? Do an experiment guys, take a rear control arm and put a shaft on both ends, do not exceed the range of movement of the heim joints. Stand on one shaft and try to have it resist your movement in any direction but up and down. If it does you have either moved it more than 10 or so degrees or your heims need replacing.
I am speaking for heim joints, not pillowballs. If the arm does have a pillow ball you may be able to load it laterally somewhat.
You guys are all caught up in a static world, the real world is dynamic. It's weird too because you learn statics in high school physics but can't graduate from engineering school without taking dynamics.
Experiment #1: Take a straw, stand it on it's end on a table now take one finger and push straight down... completely axial loading, just like your heim's provide. Now, push really hard... what happens?
Experiment #2: take two straws, cut one in half and tape it up and repeat previous test with both straws, which one can you push harder on?
Old Feb 22, 2008 | 11:02 PM
  #52
RedOut
Ok, this is why I never post. Agree to disagree. Believe what you want, but neither example you gave has anything to do with dynamics. Personally though, onasled is right, the spc's are more unsprung weight, i would/will run the ie's or make my own.
Old Feb 22, 2008 | 11:10 PM
  #53
amg6975's Avatar
amg6975
Fair enough.
Old Feb 23, 2008 | 12:07 AM
  #54
k-huevo's Avatar
k-huevo
The SPC arms are machined from billet aluminum; they are oversize but not overweight.
Old Feb 23, 2008 | 12:28 PM
  #55
S-Driver's Avatar
S-Driver
I just purchased a set of upper & lower adj rear control arms (Ultrik) from Mini Mania and I was wondering what your supposed to do with the sensor that's attached to upper arm on the drivers side?
I'm assuming this is part of the stability control......?
Old Feb 23, 2008 | 12:51 PM
  #56
totamdu's Avatar
totamdu
I think about any aftermarket control arm would be better than the stock ones. I guess it comes down to money and personal opinion. I would problably pick.......oh I'm broke, so whatever I can get for free. But thanks for the pics and opinions of different ones.
Old Feb 23, 2008 | 01:35 PM
  #57
amg6975's Avatar
amg6975
It's actually the Xenon level sensor. Just take off the second link and the bracket and push the first link all the way down.
Old Feb 23, 2008 | 01:46 PM
  #58
flyboy2160's Avatar
flyboy2160
Originally Posted by onasled
..As I've always said, show me one high performance, or full out race car the has a control arm that's split in the middle.
Well, this has nothing to do with it, since we're not dealing with an all out race car, we're dealing with a production car with very restricted access to the inboard attach points.
..It's a lame design.
Once again, incorrect. See the post above for the tradeoff.
..But, for those that choose it because of it's ease of adjustment, then you have what you want, just several pounds heavier to compensate for the poor design...
Once again, incorrect. The only extra weight on the H-sport arms due to the center split is the turnbuckle. This is aluminum, a fraction of a pound in weight, not the "several pounds" you're fond of quoting. In fact, the inertia of that arm is reduced by moving the outboard steel threaded mass halfway toward the fixed inboard end.
Old Feb 23, 2008 | 05:05 PM
  #59
PGT's Avatar
PGT
By the way, ... I like mine the best....
look familiar.....same?
Old Feb 23, 2008 | 05:36 PM
  #60
onasled's Avatar
onasled
Could be, but shinier .. . Basically all off the shelf parts.
Old Feb 23, 2008 | 06:24 PM
  #61
PGT's Avatar
PGT
niCE
Old Feb 23, 2008 | 07:54 PM
  #62
turboexempt's Avatar
turboexempt
I want to make those. How did you do it?
Old Feb 24, 2008 | 09:29 AM
  #63
Nitrominis's Avatar
Nitrominis
I will have to agree having this similar design on my MINI since 2003 with no failure in any way.
Mini X Rear Control Arms
are made from SWAGED 6061-T6 AIRCRAFT ALUMINUM. Our Rod ends are SELF-LUBRICATING and SELF SEALING with NYLAFIBER NATRIX RACE and are rated at 16,565 radial load. We exceed all others currently on the market. That's extra safety and reliability built in every piece. Also a stock bar weighs in at over 3lbs. The Mini x Rear Control Arm is only 1lb. 15oz. That is one of the lightest on the market. Installation can be done with common garage tools in less then a couple of hours. However we do recommend a professional shop install them. They come packaged in brushed aluminum and for a little extra you can have them *powder coat red, black, gray, silver or polished. Also because our rod ends are adjustable, you can change your rear camber for that weekend race or correct for lowered springs. That makes Mini X. Rear Control Arms the best out there.[/FONT]
Picture in 2003
Picture in 2007
Old Feb 24, 2008 | 09:45 AM
  #64
morbius's Avatar
morbius
Dr. Morbius
So where does one find the Mini X Rear Control Arms ?
Cheers,
Roberto
Old Feb 24, 2008 | 09:53 AM
  #65
onasled's Avatar
onasled
As I say, they are all off the shelf parts. The swagged bars are Woodwards.
The Hiems are aluminum which make them even lighter.
So, just buy the parts and install, but for the bushing that adapts the Mini bolts to the hiem. These will need to be made up on a lathe.
There is no secret here on these arms. They can be had in most any race shop. Oval track / nascar shops have some great parts. I'm lucky enough to have one of these types of shops not far from me.
Old Feb 24, 2008 | 09:56 AM
  #66
onasled's Avatar
onasled
Mini X Rear Control Arms are made from SWAGED 6061-T6 AIRCRAFT ALUMINUM. Our Rod ends are SELF-LUBRICATING and SELF SEALING with NYLAFIBER NATRIX RACE and are rated at 16,565 radial load. We exceed all others currently on the market. That's extra safety and reliability built in every piece. Also a stock bar weighs in at over 3lbs. The Mini x Rear Control Arm is only 1lb. 15oz. That is one of the lightest on the market. Installation can be done with common garage tools in less then a couple of hours. However we do recommend a professional shop install them. They come packaged in brushed aluminum and for a little extra you can have them *powder coat red, black, gray, silver or polished. Also because our rod ends are adjustable, you can change your rear camber for that weekend race or correct for lowered springs. That makes Mini X. Rear Control Arms the best out there.[/FONT]
Picture in 2003
Picture in 2007
Wow, not bad, if your saying you've had these for Four years and not replaced the Hiems?
Old Feb 24, 2008 | 10:25 AM
  #67
newbs49's Avatar
newbs49
So PTG
Where did you get your arms.
Old Feb 24, 2008 | 11:07 AM
  #68
Nitrominis's Avatar
Nitrominis
These are beyond over kill for a MINI !!!!
http://www.mini-madness.com/
Old Feb 24, 2008 | 06:02 PM
  #69
AstroBlackS's Avatar
AstroBlackS
Hey Bob! There is a thread somewhere on here where they fabbed up a little "L" bracket, that they clamped to the control arm, for the level sensor to attach. I'll try and find it.
Old Feb 24, 2008 | 07:27 PM
  #70
S-Driver's Avatar
S-Driver
Cool, thanks! I PM'd you about something else...
Old Feb 25, 2008 | 09:14 AM
  #71
kalbone's Avatar
kalbone
Originally Posted by COR BLMY
I found it ...
Now this is nothing high tech ...
I made the bracket the same length from the centerline if the OEM arm to the miunting hole.
The clamp can be rotated to adjust
(it can be done at night with lights on, then once set it is good to go)
I now have a line painted on it and can adjust the control arm and not loose my headlught adj ...
Old Feb 25, 2008 | 04:35 PM
  #72
OSUBeaver's Avatar
OSUBeaver
So is there a history of any of the aftermarket arms failing by snapping in the middle? I'm looking to get lower arms to adjust camber... looking at the megan's for price reasons. But obviously if people are breaking the megan's I'll look to spend more.
So far I've only seen evidence that the stock one's break, but I may have missed something.
Mainly I want to adjust camber and have them be quiet.
Old Feb 25, 2008 | 04:47 PM
  #73
morbius's Avatar
morbius
Dr. Morbius
Another option / route to go for the 2007 mini's is the old fashion way ....
http://www.eurosportdesign.com/pc-14...-bushings.aspx
Since the 2007+ mini have a new stronger rear control arm and not that pressed together junk, the above option will work just find and can be done for the upper and lower arms
Old Feb 25, 2008 | 06:01 PM
  #74
ScottinBend's Avatar
ScottinBend
Now that looks like it simply backed out the endlink.
Or did the endlink break at the threads like the above pic?
Old Feb 25, 2008 | 06:10 PM
  #75
ScottinBend
I have a hard time visualizing how that could happen. It would have taken quite a load to the outside top of the wheel or the inside bottom to do this.
Weird......
