Suspension No more teasing: Mach V Technic Springs now shipping.
thanks, i've been staring at your before/after photos of yours for the past couple months & knew it was the mach v springs i wanted to install. it is amazing what a little gap reduction and wheels with decent offset does to the look of the MINI.
and a
to Vinyl Styles wrapping for the de-chroming.
and a
replied by pm
Will i get any rubbing with these springs running 215/45/17 non flats...And these wheels on my 08 clubman s
http://www.tsw.com/alloy_wheels_asan_4.php
Iam pretty sure they 40mm offset..
I'm running 215/45/17 tires on 17x7" 40mm offset konig feathers and my front tires do rub on the inside wheel well liner, theres two spots towards the outside of the wheel on the driver side, and one spot on the inside of the passenger side wheel well. Its not too bad as of now, but I've only been running these wheels/tires for a month, so we will see if it eventually rubs through or not =\
Thanks but i really like the ride of the 215's plus still have over 70% tread left in my existing tires...
BostonR56S when you rub is on normal driving over bumps and corners
its on bumps/corners, not normal flat road driving. its really not THAT bad. If I were you i'd use up the rest of your existing tires and then go for 205 on the next one. It depends on the offset of your wheels too. Mine are et40, so they are pretty flush with the outside fender.
No rubbing here, but god the ride is horrrrrrible on Mach V's...maybe the stock shocks are shot but its horrible.
Ask Jan how uncomfortable my car is driving on the streets of LA
...got a few F-bombs outta him haha
smdmini
Oct 7, 2019 06:05 AM
atlantaorange
Sep 16, 2015 12:43 PM
