Suspension No more teasing: Mach V Technic Springs now shipping.
Old Aug 14, 2007 | 10:49 AM
  #26
Loony2N's Avatar
Loony2N
Not to changes the subject, but thanks for the replacement bulb, Dan. It works great!
Old Aug 14, 2007 | 02:51 PM
  #27
Mach V Dan's Avatar
Mach V Dan
Originally Posted by PGT
10,000 watts !!! (ILS*)
* If Lightning Strikes
LOL!
--Dan
Mach V
FastMINI.net
Old Aug 14, 2007 | 05:58 PM
  #28
vodkarocket's Avatar
vodkarocket
Originally Posted by Mach V Dan
That's sort of complicated, and I don't want to open up a can of worms by quoting rates. It's sort of like car stereo amplifier wattage ratings, or dyno horsepower ratings -- a simple number can sometimes be misleading, and comparisons between two different companies may not lead to an accurate result.
--Dan
Mach V
FastMINI.net
I don't know how stating the spring rates would "open up a can of worms" but I do know that knowing the spring rates would help me to make an informed decision in purchasing the right set of springs for my car. The numbers don't lie...
Old Aug 14, 2007 | 06:16 PM
  #29
Mach V Dan's Avatar
Mach V Dan
Okay, so, you're going to compare to...what? The factory spring rates? Which are...? And the H&R springs? (That's the only other currently-available spring that I know of.) What are their rates? And do we take the rate at each inch of travel? The rate at which the rate stops changing? The initial rate? Is that the initial rate of the spring unloaded? Or the rate when the spring is on the car? Which car?
So, given the complexity of what at first sounds like a simple question, I'd rather not get into it. Sorry. Lots of other spring manufacturers do the same, although some do quote rates (usually of linear springs, though).
If you don't think you can purchase without the hard numbers, give it a little time, and people will start posting their own reviews. Then you won't have to take my word for it that they work nicely.
--Dan
Mach V
FastMINI.net
Old Aug 20, 2007 | 08:26 AM
  #30
RoadRacer's Avatar
RoadRacer
Ordered a set last week - should be here Wednesday; hope to have them installed by early next week, and will try to post pics then.
Old Aug 20, 2007 | 01:09 PM
  #31
scott48's Avatar
scott48
Yessss...my Mach V springs just arrived...look nice
Old Aug 20, 2007 | 02:01 PM
  #32
familiarstranger's Avatar
familiarstranger
post pics when they are on scott!
Old Aug 20, 2007 | 02:38 PM
  #33
scott48's Avatar
scott48
Will do...I have the before shots, so just need the after shots
Old Aug 21, 2007 | 06:18 AM
  #34
Turn In Concepts's Avatar
Turn In Concepts
--Dan
Mach V
FastMINI.net
We know Dan, and we know Dan's work. It's always first rate, and leaves no worries in our minds on these.
Old Aug 21, 2007 | 10:03 AM
  #35
JBgotM's Avatar
JBgotM
--Dan
Mach V
FastMINI.net
That approach probably works just peachy for people who want daily driver springs and don't really care as long as the car feels good. Thats kinda the point of progressive springs anyway.
When I buy a suspension, I want to spec out my spring rates (linear), know my motion ratios, get matched valved shocks for right wheel rate and car weight, and choose bars to suit my preference in balance.
I do think you nailed a great ride height and the price is very good.
Old Aug 24, 2007 | 11:17 AM
  #36
Mach V Dan's Avatar
Mach V Dan
Originally Posted by JBgotM
When I buy a suspension, I want to spec out my spring rates (linear), know my motion ratios, get matched valved shocks for right wheel rate and car weight...
Hmm. Sounds like you're going to want a coilover setup. That's the only way I know to specify your suspension with that level of precision, and even at that you may have to custom-order the springs, if the springs that are included with the coilovers are not to your spec.
--Dan
Mach V
FastWRX.com
Old Aug 28, 2007 | 07:15 PM
  #37
RoadRacer's Avatar
RoadRacer
Mach V Springs are installed...
Big thanks to Peter at Minspeed!
Mach V springs went in yesterday along with a 19mm rear swaybar from Minspeed, and a performance alignment. I'm very pleased with the look, and the ride quality is very even, without much bounce, so I think it's gonna work well.
Should have before & after pics tomorrow night - springs dropped the car right about 1.25" as expected... now it's got "the look".
Dan, so far the springs seem to be winners, and this weekend will be track days at Homestead to see how it does.
Old Aug 29, 2007 | 06:23 PM
  #38
RoadRacer's Avatar
RoadRacer
Before & after pics - Mach V Technic Springs
Here's the outcome of the spring swap... The Mach V's dropped the car about 1.25" - just enough for my liking without ruining the ride quality.
Old Aug 29, 2007 | 09:38 PM
  #39
ltjpunk7's Avatar
ltjpunk7
Looks great, RoadRacer! I agree, perfect amount of drop.
Old Aug 30, 2007 | 02:24 PM
  #40
Mach V Dan's Avatar
Mach V Dan
Looks great!
--Dan
Mach V
FastMINI.net
Old Aug 30, 2007 | 07:26 PM
  #41
sirr6's Avatar
sirr6
So, if I were to buy a set of these, would I need control arms?
Old Aug 30, 2007 | 08:02 PM
  #42
Mach V Dan's Avatar
Mach V Dan
Uh, you already have control arms.
Do you mean ADJUSTABLE ones? Then the answer is no.
--Dan
Mach V
FastMINI.net
Old Aug 31, 2007 | 02:40 AM
  #43
sirr6's Avatar
sirr6
Yea, that's what I meant, I would like to purchase a set, but don't know if I would need to purchase anything else. Would I need to cambers or anything to keep the tires from butterflying?
--Dan
Mach V
FastMINI.net
Old Aug 31, 2007 | 06:01 AM
  #44
RoadRacer's Avatar
RoadRacer
I didn't need to change the control arms, and there is enough adjustment to enable some additional camber if desired; I have mine setup for combo street/track use, and adjustment was not a problem. You don't need (more) adjustable arms unless you just want them to look prettier.
Old Sep 1, 2007 | 08:09 AM
  #45
chuck r's Avatar
chuck r
Thats perfect. Great looking ride.
chuck
Old Sep 1, 2007 | 01:00 PM
  #46
scott48's Avatar
scott48
Just got mine installed today along with JCW shock-struts and rear sway bar(not enough time for front bar)...drop looks great...will post pics:~)
Old Sep 1, 2007 | 07:15 PM
  #47
scott48's Avatar
scott48
So here's my car with the Mach V springs:
Before:
After:
Before:
After:
Perfect drop...love um plus the handling
Old Sep 1, 2007 | 07:24 PM
  #48
PGT's Avatar
PGT
looks good! about the height of my R53 stock
I drove Mach V's R56 with H&R and with their Technic springs. Both are nice...good to have options
Old Sep 1, 2007 | 10:03 PM
  #49
sirr6's Avatar
sirr6
has anyone lowered their cars on stock shocks yet?
Old Sep 2, 2007 | 12:23 AM
  #50
ltjpunk7's Avatar
ltjpunk7
ummm...just about every person on the website that has lowered their car, minus a few. check some more around the suspension threads.
