Suspension Ireand Eng. adjustable control arms squeak...
Old Jun 3, 2007 | 09:27 AM
robino's Avatar
robino
So after about 2-3000 miles of driving on the Ireland Engineering control arms (both upper/lower), my wife was telling me of a squeak coming from the back, checked it out, sure enough, when moving the control arms up and down they squeak at the bushings.
So i sprayed some silicone/lubricant at and around the bushings and it went away for a few weeks, now it's come back a little bit.
Is there a fix for this or do i need better lubricant? KY...? Vaseline?
Old Jun 3, 2007 | 03:05 PM
meb's Avatar
meb
...ah...Mobil 1 synhtetic grease generaosly applied to everything. They never made a sound for nearly a year - thru a winter too. Don't expect those poly bushings to last long...make sure you check them often. Mine went bye bye at about 20K miles and let loose on during a track event cause a wild spin -off that caused the car to become air born
Old Jun 3, 2007 | 03:48 PM
ScottRiqui's Avatar
ScottRiqui
Are your IE control arms the "street/race" version with the cylindrical poly bushings, or the "race" arms with the heim joint ends?
Old Jun 3, 2007 | 09:14 PM
robino's Avatar
robino
cyl. poly bushings, no heim joints.
Old Jun 4, 2007 | 05:18 AM
meb's Avatar
meb
...my IE non-teflon lined hiem joints lasted about 5-6K miles on public roads. That equates to a fair amount of track miles...and I would expect more miles from these on the track, but not a lot more.
The hiem joints replaced the poly...
Old Jun 7, 2007 | 07:36 AM
robino's Avatar
robino
really
so IE doesn't really have a fix for this?
just regular greasing of them?
Old Jun 7, 2007 | 04:23 PM
PenelopeG3's Avatar
PenelopeG3
Probably not. That is the case for just about any poly urethane bushings. That is why they are considered more of a race or track oriented upgrade on most cars.
Might want to call them to see if they recommend any special type of grease for their bushings. I know sometimes certain types of grease work better on poly than others.
Old Jun 12, 2007 | 05:57 AM
robino's Avatar
robino
they should have sold some grease with their arms...
now i gotta crawl under there and experiment with different types of grease?
Arghhhhh!!!!!!
IE should chime in and offer me some goodies for free real soon before i get angry
Old Jun 12, 2007 | 11:31 AM
meb's Avatar
meb
IE won't chime in...I doubt they follow...
I've never experienced a manufacturer pre-lubing poly...usually up to the end user. It's easy, but a PITA since the control arms have to come out and bushings removed. Figure 1 - 1.5 hours
Old Jun 14, 2007 | 08:43 PM
jefeant's Avatar
jefeant
Ireland engineering stuff squeaks. I have their 22mm swaybar and it works great BUT it squeaks like a SOB... while going slow though.
patsum
26
May 29, 2021 06:29 PM
Gen1Parts
Sep 7, 2015 03:50 PM
yukinoinu
Sep 7, 2015 02:46 PM
Gen1Parts
Sep 7, 2015 01:37 PM
Ntety
Sep 2, 2015 08:39 PM
