Replace Bowden Cable
According to Wikipedia...
Invented by Frank Bowden, a bowden cable is a type of flexible cable used to transmit mechanical force or energy by the movement of an inner cable (most commonly of steel or stainless steel) relative to a hollow outer cable housing. The cable housing is generally of composite construction, consisting of a spiral steel wire, often coated with plastic, and with a plastic outer sheath.
The linear movement of the inner cable is generally used to transmit a pulling force, although for very light applications over shorter distances (such as the remote shutter release cables on mechanical film cameras) a push may also be used. Usually provision is made for adjusting the cable tension using an inline hollow screw (often called a "barrel adjuster"), which lengthens or shortens the cable housing relative to a fixed anchor point. Lengthening the housing (turning the barrel adjuster out) tightens the cable; shortening the housing (turning the barrel adjuster in) loosens the cable.
Mine came free from the outside handle mechanism a few weeks ago. I went by the shop and asked them how to take the door panel off. pretty simple. don't forget there's a screw behind the small reflector. Tight space to work but after 5 mins or so i got the anchor point back where it belongs. Sorry i didn't take pictures.
Anyone have a schematic of the door cables?
Everyone seems to have problems with the interior handle cable.......but I also have a problem with the exterior handle cable.........and I cannot figure out where the cable secures........did you purchase a new cable? And do you have illustrations of where things go to re-assemble?
Much appreciated.
Craig
Much appreciated.
Craig
This link may help, theres links and pics in it. https://www.northamericanmotoring.co...d.php?t=138109
Navigation & Audio MINI Branded nuvi 360 Installation
Super Coop
Aug 17, 2015 05:09 PM
