Anything made to replace oil-filled engine damper?
Old Apr 12, 2007 | 07:59 AM
Squirlz's Avatar
Squirlz
The engine mount damper on my '05 has once again spilled its guts all over my engine compartment. This is one that was installed just last June after my original one gave up.
Is there anything made to replace this piece of crap?
Old Apr 12, 2007 | 09:06 AM
rkw's Avatar
rkw
I posted the following last year. You could be on the borderline for when a possibly improved mount may have come out. I'd say just have the dealer replace it and hope for the best.
Originally Posted by rkw
Here's the TSB. From the reports on NAM and MINI2, it's clearly been a chronic problem. The TSB applies to builds from December 2003 to May 2006. Starting from June 2006 they hopefully began to use an improved mount for builds and replacements. If anyone has a newer mount that still failed, please post.
Edit: the link doesn't work any more. Unfortunately Alldata now requires you to purchase their service for access to TSBs. It had been a free service for several years and it was good while it lasted.
Old Apr 12, 2007 | 11:23 AM
Squirlz's Avatar
Squirlz
Thanks rkw. I probably have an "old and unimproved" one. Because my dealer will not order parts without doing their own diagnosis (which would necessitate two 180 mile round trips and two days off work) I ordered the part myself ahead of time through their parts department. If they had gotten the RIGHT PART it might have been an improved one. Because they ordered the wrong part, they took a damper off a new car that they had on the lot. This was very nice of them. It's just unfortunate that it crapped out after only 10 months.
Old Apr 20, 2007 | 04:58 PM
hctiev's Avatar
hctiev
I'm in the same boat. Oil (and rather stuborn oil at that! ) all over the engine compartment.
So I take it there isn't an aftermarket part option available - right?
Old Apr 20, 2007 | 08:39 PM
erickvonzipper's Avatar
erickvonzipper
Either of the remote mount engine dampers available through this site (TSW or LOTF) should take some of the stress off of the stock damper. And they both improve shifting, as well.
Zip
Old May 5, 2007 | 06:17 PM
astrochex's Avatar
astrochex
Whoo hoo, I just joined the failed damper club!
I moved my car out of the garage and there was spooge on the ground, wtf over? Took a peak to see where the drip was coming from and worked my way up to the damper and there was the culprit.
I'm still under warranty so first thing Monday, I'm making a service appointment with my dealer.
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
bobbiemartin
Jan 20, 2016 05:28 PM
silence2-38554
Nov 12, 2015 09:39 AM
Emnotek
Aug 13, 2015 05:47 PM
PatrikKN
Aug 5, 2015 09:10 PM
