Popping sound after shutting off engine?
Old Nov 21, 2006 | 08:04 AM
goldy27's Avatar
goldy27
I noticed that there is a popping sound coming from the bottom of the car when the has been parked after I have driven it for awhile. This sound was not there until I installed the M7 16% pully and 2% crank pully. Could this be the heat shield?
Thanks for the help.
Old Nov 21, 2006 | 09:10 AM
mdsbrain's Avatar
mdsbrain
I don't think any of your heatsheilds should of been affected during the install of those pullies. You might be hearing what was explained here.
Old Nov 21, 2006 | 10:36 PM
goldy27's Avatar
goldy27
Thanks for the reply. Actually that sound is nothing like that everyone is talking about. I mean this is coming from underneat the engine that just keeps poping. It pops like if someone is hitting a hammer against a metal pipe. I will do a run and lift it to track it down over the weekend.
Thanks for your help
Old Nov 22, 2006 | 05:00 AM
mdsbrain's Avatar
mdsbrain
I've heard a similar noise like this on other brands of cars. I've been told in the past this is just the oil returning to the pan. But I find this partly hard to believe and I have never heard it on my MINI.
Old Nov 22, 2006 | 07:58 AM
MCDriver's Avatar
MCDriver
it is the exhaust system cooling.
Old Nov 22, 2006 | 01:22 PM
herbie hind's Avatar
herbie hind
with the pulley additions i'd suspect more heat at the header;cat. as mentioned above could be the cat cooling down. you may (as has been sugested here by others) try running colder plugs to help with the heat.
rob&JCW
Feb 13, 2023 07:03 PM
R60abq
R60/R61 Stock Problems/Issues
Jun 6, 2017 05:15 PM
makg
Aug 21, 2015 02:49 AM
wind715
Aug 11, 2015 07:56 AM
