Noise after engine shut off
Old Nov 17, 2006 | 08:36 AM
RonP's Avatar
RonP
After I shut the engine off, for about 5 seconds I hear a buzzing noise then a click right before it stops. It happens everytime and lasts for the same duration everytime. It's not the high-pitched sound from the PS, but I am at a loss to figure out what it is or where it's coming from. It doesn't last long enough to give me time to track it down.
Any ideas as to what it may be?
Old Nov 17, 2006 | 09:20 AM
kenchan's Avatar
kenchan
it's winding up itself for your next run.
mine does that too. perfectly normal.
Old Nov 17, 2006 | 09:27 AM
Greatbear's Avatar
Greatbear
Moderator :: Performance Mods
Most likely the air conditioner resetting the air positioning controls. Perfectly normal.
Old Nov 17, 2006 | 09:49 AM
RonP's Avatar
RonP
Thanks guys.
When I bought her my neighbor said I should get a plastic wind up key and stick it on the back.
Old Nov 17, 2006 | 03:35 PM
herbie hind's Avatar
herbie hind
that's funny ..... tell im' to get bent.
Old Nov 17, 2006 | 04:36 PM
Rawhyde's Avatar
Rawhyde
Originally Posted by RonP
Thanks guys.
Not a bad idea, but actually they're metal! http://www.windupkey.com/
Rawhyde
PS The mysterious sound you hear could also be vacuum bleeding off through the PCV valve. There have been threads on that subject before.
Old Nov 17, 2006 | 04:58 PM
oldtrojan66's Avatar
oldtrojan66
I believe I read somewhere, that this sound is the damper on the ventilation system closing, after the ignition is turned off.
Old Nov 17, 2006 | 10:01 PM
RonP's Avatar
RonP
I also noticed today that when I put the key in and turn it all the way just shy of turning the car on I hear it as well.
Old Nov 17, 2006 | 10:10 PM
Fatherdeth's Avatar
Fatherdeth
I believe it's the fuel pump kicking on before start up, and then shutting off when the car is turned off.
Old Nov 17, 2006 | 10:58 PM
ma78's Avatar
ma78
Coordinator :: Super Secret Orange County MINI Cooper Club
Looks like a lot of ideas. I think that it's elves making cookies. Anyone know for sure?
Old Nov 18, 2006 | 12:19 AM
valcom111t's Avatar
valcom111t
Does it sound kinda like when you eject a CD?
Old Nov 18, 2006 | 03:33 AM
oldtrojan66
I vote for cookies! That would make the mini the most perfect car on the road, if it isn't already!
Old Nov 18, 2006 | 10:27 AM
RonP's Avatar
RonP
As long as there peanut butter cookies or oatmeal, it's all good.
Exactly my thought as well.
Does it sounds kinda like when you eject a CD?
Yes, a good description.
Old Nov 18, 2006 | 10:31 AM
lilcoopr's Avatar
lilcoopr
Yeah I have a sound that reminds me of a jet engine (quieter though!!) powering down. Some kind of fan. Sounds like it's to the left or behind the steering wheel. Is this the same sound you guys are talking about? I've heard it since day 1 so I'm guessing it's normal...
Old Nov 18, 2006 | 10:37 AM
MaxN's Avatar
MaxN
Reverse Gear
Is is the infamous power steering motor fan ?????
I am half-deaf I never notice such things.....
Old Nov 18, 2006 | 11:23 AM
002's Avatar
002
I think that there are a few things that people are describing. Here are a few of the normal noises that you may be hearing.
1) When turning the key on a ligh buzz from the rear seat and a faint click from the fuse panel by your foot. This is the fuel pump pressurizing the rail and then the relay deactivating.
2) When turning the key on and sometimes off there is a slightly deeper buzz from the throttle body and then one or two clacks. This is the throttle initializing itself. This is what I think the poster is hearing.
3) When shutting the engine off there is a "winding down" sound from the engine bay. It sounds like the supercharger bleeding off boost or slowing to a stop, but it is the power steering pump not the fan. Sometimes it stays on until the key is cylcled again (could this be a cause of engine fires?)
Old Nov 18, 2006 | 01:18 PM
RonP's Avatar
RonP
Bingo, thanks 002, that's exactly what I've been hearing.
Old Nov 26, 2006 | 08:09 PM
Flyer's Avatar
Flyer
I vote for the throttle body. It also does something similar when the car is shut off. The IAC (idle air contrl) keeps the TB blade open slightly to keep the idle perfect. Once the eingine is shut off the goes into a rest state where you hear it slamming shut.
Old Nov 29, 2006 | 04:36 AM
rjyoder4's Avatar
rjyoder4
I tell people it's my machine guns retracting.
woodstudio
Mar 15, 2020 08:28 AM
cerenkov
Apr 24, 2018 07:47 AM
R60abq
R60/R61 Stock Problems/Issues
Jun 6, 2017 05:15 PM
patrioticmini
Aug 20, 2015 10:54 AM
damncajun
Aug 17, 2015 08:25 PM
