i dropped my nut
Old Sep 3, 2006 | 04:37 PM
mataku's Avatar
mataku
i dropped my nut
I was installing the remote control auto up module today. I removed the connections to the battery and unforunately i stupidly removed the nut holding the positive connection. As i was putting it back on, it slipped and fell down and now I can't find it. I tried looking for about 30 min from the top and the bottom, but no luck.
At this point was is the best solution? I can easily get another nut, but I am worried about any possible damage the nut can do in there. Should I continue looking or should I just replace it and give the MINI a good go around hoping the nut will fall out?
any help is appreciated.
Old Sep 3, 2006 | 04:42 PM
gokartride's Avatar
gokartride
I will reserve comment on this subject until I can do so with a straight face.
Old Sep 3, 2006 | 04:46 PM
MINIclo's Avatar
MINIclo
7th Gear Gal
You need a gadget like a long stick with a magnet on it, and another one with a mirror attached to it, to search and collect the nut. So frustrating when such things happen! Good luck and happy puberty! (Sorry...couldn't resist!)
Motor On's Avatar
Motor On
Can you see where it landed?
There are other parts of the abyss I know things are ok, however around the intake is not one of them (Shift cables and other moving parts not friendly to nuts). Something many peple use is a magnet on an extention (loos like a slide show pointer). If that's not availible a long screw driver with a manetic tip.
Couldn't have had a better title I wouldn't settle for just any nut. If it started there then make it finish there.
Old Sep 3, 2006 | 04:47 PM
MINIclo's Avatar
MINIclo
7th Gear Gal
Jinx, Drew! Same idea, same posting time!
Old Sep 3, 2006 | 05:12 PM
mataku's Avatar
mataku
i tried shifting cables and everything for a while, but I just can't seem to find the dang thing. I will try the magnet idea. What about getting a air hose in there and just trying to blow things around, would that work?
Old Sep 3, 2006 | 05:13 PM
MINIclo's Avatar
MINIclo
7th Gear Gal
What if you blow it further in where you can't get to it? I like the magnet idea better, mataku! Good luck!
Old Sep 3, 2006 | 05:15 PM
mataku's Avatar
mataku
Darn, if the magnet idea doesn't work, which will be better, simply driving or using the hose. I need to know so I know if I should pick up the nozzle for the air hose.
O, the woes of losing a nut.
Old Sep 3, 2006 | 05:17 PM
Motor On's Avatar
Motor On
Air might work. Another thing that has been done succesfully (but be warn your neighbors may start asking questions) is driving inreverse quickly then slaming on the brakes and the same going forward. Several times yusually dislodges lost nuts. Have you treid jacking up just the front to see if you can get it to roll out (be sure to follow normal safety precautions)?
Old Sep 3, 2006 | 05:27 PM
daemon2's Avatar
daemon2
Telescopic magnetic grabber, sometimes sold with a mirror. Unless you are
speaking of the fleshy kind of nut.
Old Sep 3, 2006 | 05:51 PM
agranger's Avatar
agranger
You can find a full assortment of these tools to help you get your nut off... um, I mean out, at Sears in the tools department.
Old Sep 3, 2006 | 06:11 PM
DarkMiniCooperS's Avatar
DarkMiniCooperS
That thread's title sure got my attention, but I was a little scared to open it and read the whole story!! lol
Seriously, the magnetic stick is your best bet!
Old Sep 3, 2006 | 06:24 PM
MINIclo's Avatar
MINIclo
7th Gear Gal
This gadget should be standard equipment!
Old Sep 3, 2006 | 06:30 PM
Xman's Avatar
Xman
I've had that problem with a small screw a year ago. I did try everything (magnet, air blower, etc...) but to no avail. I finally got it weeks later by going underneath the car and do a "hand search".
Good luck.
Old Sep 3, 2006 | 06:34 PM
TheWrks's Avatar
TheWrks
Coordinator :: Michigan MINI Motor Club
Yes everyone should have a magnetic nut grabber....
Old Sep 3, 2006 | 06:35 PM
kenchan's Avatar
kenchan
i recommend going under the car and searching where the front subframe
connects to the chassis. there's a black flat bar about 4-5inches in width. i bet
it landed on that. or remove the front air diverter just under the radiator...
or search where the front bumper wraps around the front end. could've bounced
towards the front.
Old Sep 3, 2006 | 06:43 PM
welshmenwillnotyield's Avatar
Another nasty possibility is that the nut is aluminum. If that is the case, all the magnetic nut grabbers in the world won't help ya, but you MAY manage to grab it with one of those spring loaded devices, OR knock it into view with a thin screwdriver.
Old Sep 3, 2006 | 07:31 PM
mataku's Avatar
mataku
it definitely is grabable. or at least I think, since all the other nuts seem to be. I have already checked the front subframe area under the car, done a hand search, I saw a couple pieces of rocks, but no nut. I tried poking around for about 20 minutes, I guess now it's time to go from under the car.
I'm tempted to just whip the car around sheridan road and maybe it'll get thrown out. lol
thanks for all the help so far though guys.
Old Sep 3, 2006 | 07:36 PM
Motor On's Avatar
Motor On
I did that just last night.
Old Sep 3, 2006 | 09:35 PM
mataku's Avatar
mataku
okay, i give up. I took off the tires as well and I still couldn't find it. Crossing my fingers I started the car and it didn't blow up, so I would say that it's good so far. I guess it will be a lost nut, can I just get a new one at home depot? or autozone? or do I have to get it from the dealer. Since it seems to just hold the battery connector, doesn't seem like i need anything special.
on a better note, the Remote control auto up module works GREAT!!. I love this thing and to think I was almost willing to spend 300 for this option.
Old Sep 3, 2006 | 09:54 PM
kenchan's Avatar
kenchan
you don't need a special nut for it.
Old Sep 3, 2006 | 11:35 PM
Motor On's Avatar
Motor On
The depot should carry it, and I bet you'll find in your driveway or just down the street when the sun is up, a day after you replace the bolt, accordig to Mr. Murphy.
Old Sep 4, 2006 | 04:45 AM
Ords's Avatar
Ords
perhaps his girlfriend can assist; she can lay on the ground looking up and he can be on top looking down. Between the both of them, if can't find his nut, it's a lost cause.
Steffen.Johnson
42
Jan 25, 2023 02:47 PM
Doc Pain
Mar 10, 2021 04:50 AM
vetsvette
Oct 11, 2015 06:05 PM
navybsn
Oct 4, 2015 03:27 PM
aldito2
Sep 30, 2015 10:44 AM
