Idle Issues With P0507 Code
Old Aug 22, 2006 | 09:24 AM
jimz68's Avatar
jimz68
Iv'e done a search but wanted to see if anyone has any other ideas.
Idle will sometimes fluctuate between 1000-1500, or it will hang up on decel then idle normally. Pulled code P0507 (Idle Control System RPM Higher Then Expected).
Thanks!!
Jim
Old Jul 15, 2008 | 03:56 PM
rl48mini's Avatar
rl48mini
P0507
Bump back TTT.
I've recently had the same problem. Car is a '03 MCS and has 105K and the usual mods: pulley, CAI, 2.5" one-ball, header, hi-flow cat. The post-cat O2 sensor was replaced along the way (about 20K ago).
After clearing the code, the car was running great and then when stopped, the idle would jump up to about 1200-1500 rpm and then throw the SES light.
I've recently changed the belt and cleaned the filter and cleaned the throttle body. The car behaved for a day or so and now the code is back along with the SES. I just read a few threads and still have to check the IC for possible cracks but in the mean time, does anyone have any other ideas where to look for possible causes?
Thanks!
Old Jul 15, 2008 | 03:58 PM
Dr Obnxs's Avatar
Dr Obnxs
Mild Vacuum leak?
More air in the intake than planned would do that. TB can't close enough to lower the engine speed. FWIW, fast RPM changes are done by timing (that's why it bounces all over the place) but slow changes are done by TB position....
Matt
Old Sep 14, 2013 | 12:23 AM
PaulWalliDumali's Avatar
PaulWalliDumali
I just got this problem. I would appreciate any information to help me check somethings before I spend money at the shop. I just don't know what I am looking for.
Old Jan 23, 2021 | 01:04 PM
Eric Spurrell's Avatar
Eric Spurrell
Solved High Idle issue Code P0507
I just solved this on my 16 MCS F56. I started noticing high idle rpms when the engine was already warm...think sitting in traffic or at a drive through...then the Check Engine Light came on....ran my scanner and it pulled this code P0507 "Idle Air Control System RPM Higher than expected." After some research, it was determined to be a failed or failing Fuel Tank Breather Valve. Did a RealOEM part search and voila....ordered the part $180 CDN, and installed myself in 15 minutes. Cleared the code with my scanner and done. For the 16 MCS F56 this is tge part # 13907621174 but just ask Mini to confirm via your VIN and you should be fine. Here's what the part looks like. Easy to access and replace...one clip for the wire and two hose clamps push and release. To access it, you just need to pull off the engine head cover....be careful....these can break when cold!
Engine cover removed.
Furl Tank Breather Valve 16 MCS Hatch
Its part 1 in this diagram
The part is on top of this so you need to remove the engine cover.
Old Feb 3, 2021 | 01:21 PM
Michał Hajduk's Avatar
Michał Hajduk
Help
hello, also you had increasing idle speed fluctuating up to 1.5 rpm? ... I have it sometimes, suddenly it starts to add gas itself and after a while it drops and then again ... also not always .. sometimes the whole day is ok :(
Old Feb 3, 2021 | 06:07 PM
Eric Spurrell
YES - Idle rpms increased between 1.5 and 2.0. It did this for about a week before the check engine light came on.
Old Feb 3, 2021 | 11:12 PM
Michał Hajduk
Also at idle? .. because I only stop and not always. .. maybe replace the valve today .. no error indicator is on now .. only suddenly after stopping the car it increases the speed by itself to 1.5 rpm and after a while it drops and then again .. ehh I hope this is the car valve from 2015 MCS thanks !!!
Old Feb 17, 2022 | 05:00 AM
MINI Duke's Avatar
MINI Duke
Thanks for posting! I have a F56 as well and I saw this pop up a few months ago. I’ll try to get the part and hopefully it fixes it. I also have an evap leak P0456 code I changed my gas cap but it still does it.
Old May 9, 2022 | 02:48 PM
MiniDad08's Avatar
MiniDad08
MiniDad09
We just started to experience similar issues on our 2016 R57. Thank you for your post. Can you provide any tips on the "Push and Pull" clamps to release this valve? I've located the valve and as you mentioned, it is easy to access. I'm just not familiar with the push pull clamps on this vehicle and do not want to break anything if at all possible.
Thank you in advance for any guidance you can give on replacing this valve. FWIW, I was not able to find any Youtube videos that shows more detail than you have provided. If at all possible I would like to replace this valve with the one listed on ECS Tuning website. Actually would not mind replacing the gas cap also.
https://www.ecstuning.com/b-genuine-...e/13907621174/
Regards,
Jeff Gray
Old May 11, 2022 | 11:40 AM
We can get some bosch direct but it will take a couple days.
https://www.ecstuning.com/b-bosch-pa...907621174~bos/
Old May 11, 2022 | 04:55 PM
MiniDad08's Avatar
MiniDad08
MiniDad09
Mini Fuel Vent Valve Extended Warranty
Thank you ECS Tuning!
I was just in your place today and was about to purchase a new Mini vent valve from Kyle when my Classic Mini dealer called me to inform me about the extended warranty Mini issued on these valves. Kyle was extremely helpful and understanding as we canceled the transaction., Great place you have there in Wadsworth. Certainly plan on doing business with you in the future.
Fuel Vent Valve 10 year / 120K extended warranty. (see attached)
Hairy W Bush
Apr 9, 2020 04:51 AM
mini907
Jun 8, 2019 06:12 PM
burgerdog
Apr 5, 2012 05:50 AM
eduel
Jan 10, 2011 05:26 PM
cornflake5150
Oct 31, 2010 09:01 PM
