Broken Paddle shifter
Old Aug 12, 2006 | 01:32 PM
MrV's Avatar
MrV
So one of my paddle shifters broke the other day. It is now "loose" (doesn't return to the middle position - Kinda like a spring broke) and is now a "flappy paddle" in every sense of the word (with emphasis on the "flappy").
Anybody else heard of this happening to an MCSa? It's a little disconcerting to say the least.
Old Aug 12, 2006 | 02:45 PM
skitelluride531's Avatar
skitelluride531
I use my paddles (or the shift ****) in my MCSa 100% of the time when I am driving. Mine are still good as new after 14,000 miles. What did the dealership say?
Old Aug 12, 2006 | 08:01 PM
MrV's Avatar
MrV
I haven't taken it to the dealership yet. This happened on my way home from work yesterday, so by the time I got home it was cutting it close to getting there and back before being where I had to that night.
I did call though, and was told to bring it on in. The SA was a little concerned that it was still functional (as in.... it would still shift) but would shift at innappropriate times.
What concerns me is that this is the paddle that I use almost all the time. For one reason or another, I hardly use the other one. Just my dominant hand I guess...... I worry that this will be a continual wear issue. I don't want to have this issue every 17,000 miles or so.
And before someone asks, I don't bang it around. I tap it with appropriate force.
Will update when the dealership tells me something. I'm taking it in on Monday.
Old Aug 13, 2006 | 10:57 AM
DarkMiniCooperS's Avatar
DarkMiniCooperS
Don't be shy to complain and make sure the dealer fix it... It is not like if you would have broken it in 2 parts... It an internal problem and should be fixed by the dealer, and covered by the warranty!
Old Aug 13, 2006 | 12:11 PM
MrV's Avatar
MrV
I don't think that will be a problem. I have a pretty good relationship with the SA at my dealership. He's always taken care of me and others in the past with no arguments on warrantly work.
I mainly wondered if this was a problem that any others had experienced. Like I said, if this is an easily worn part, this won't be the last time I repair it.
Old Aug 20, 2006 | 07:41 PM
MrV's Avatar
MrV
Got my car back after a couple of days at the dealership.
Verdict was Mechanical Failure of the shifter system inside. My SA said he could have just replaced a piece or two, but opted on the safe side and replaced the whole assembly (under warranty of course).
Worked fine at autocross this weekend.... (too bad my brain didn't - my times were abysmal).
RobbyD
Jan 29, 2019 01:22 PM
02miniSguy
Nov 17, 2015 10:29 PM
vetsvette
Oct 1, 2015 12:59 PM
MINI Stupor
Oct 1, 2015 11:36 AM
B1mm3r101
Oct 1, 2015 06:22 AM
