Pulley Puller...
Old Jul 3, 2006 | 01:38 PM
british kompressor's Avatar
british kompressor
Pulley Puller...
for those who have done a pulley swap before, do you think this would get the stock pulley off?
http://www.canadiantire.ca/assortmen...romSearch=true
Old Jul 3, 2006 | 01:50 PM
british kompressor
I already have this tool, but I dont want to stay stuck with the engine lifted and unable to get the stock one out. Since I'm in Montreal, there are no MINI performance shops that I can borrow a puller from...
Old Jul 3, 2006 | 06:35 PM
british kompressor
anyone???
Old Jul 3, 2006 | 06:42 PM
ChiliCooperS's Avatar
ChiliCooperS
You can get it off with a zip-code input window? WOW!
Sorry for the sarcasm...
Mikey
Old Jul 3, 2006 | 06:45 PM
Partsman's Avatar
Partsman
Legion_of_Doom
It's hard to tell from the pic in the link. Even if you can get the jaws on the pulley there's really nothing to keep them there while you're cranking on the center bolt.
You could easily modify that puller to take the pulley off, if you have a decent metal/machine shop guy around.
Old Jul 3, 2006 | 07:29 PM
british kompressor
Mikey
sorry, here is another example:
http://www.midwayautosupply.com/deta...ption.asp?1811
Old Jul 3, 2006 | 07:48 PM
Daddy Duper's Avatar
Daddy Duper
Tried it, Don't Recommend It!
Yes - I attempted to remove my stock pulley using almost the identical puller. If I showed you what the pulley looks like now, you would run screaming to Randy Webb for a proper puller.
I would strongly recommend that you get the tool that is designed for removing that specific pulley. It is unbeleivable how tight the stock pulley is on there, and (in my case at least) the 3 jawed puller just curled the pulley in at those three points of contact. The tool folks like Randy use pulls in contact with the grooves all the way around the pulley.
In the end, mine came off, and my new Alta 15 is in place and working well. There were a good couple of hours there, though, where I was hugging my knees in the corner of the garage and rocking myself hoping I hadn't blown 'Ol Coopie to smithereens...
DD Duper
Old Jul 3, 2006 | 08:02 PM
british kompressor
wow, not the answer I was looking for...
it actually curled up the pulley??? thats crazyness!!
I'm trying to find something that wont force me to buy a 100$+ tool (+taxes+shipping+customs) that I will use once...
Old Jul 3, 2006 | 09:15 PM
BBCooper's Avatar
BBCooper
Not sure where you are...
But you might ask around for a local one to borrow....
Or you can rent one from Mini Mania for $1 if you buy the pulley from them at the same time....
I ended up buying a deluxe puller from OutMotoring. A nice quality product. It made the job so easy and comforting when removing the stock pulley it was well worth it (in my mind)..
I have read about others trying to use the 3 arm pullers... The engine will need to be lifted higher, and more parts will need to be removed to make clearance for the 3 arm puller to grab the pulley... All adding up to more time & potential problems.
Besides after your pulley upgrade - your friends will want help too. It would be nice to have the right tools in the box...
Good luck... in the end it is worth the effort...
Old Jul 3, 2006 | 10:05 PM
not-so-rednwhitecooper
I used one just like that.
It beat the hell out of the stock pulley, but it got it off.
You can get one for free at Autozone, just leave a deposit and you get it all back when you return it.
The only other part you need to remove is the tensioner. It was super easy and the engine didnt need to be lifted any higer than when using a Alta or simmilar puller.
Really, what does it matter what it does to the stock pulley? Are you ever gonna press it back on? Didnt think so.
Old Jul 5, 2006 | 06:36 AM
Bigcoyote's Avatar
Bigcoyote
Hey there,
I know my pulley was on there super tight - I used the puller from Mini-madness - it worked as advertised, no problems. The whole job took about 2 hours.
Old Jul 5, 2006 | 06:40 AM
qwertmonkey's Avatar
qwertmonkey
You can rent one from ALTA for $19.99. You pay the $200, but $180 is refunded when you return it.
Pulley rental
Old Jul 5, 2006 | 08:52 PM
matma92ser's Avatar
matma92ser
WMS loans out their pulley puller for free when you buy a pulley from them.
Old Jul 5, 2006 | 09:08 PM
namwob's Avatar
namwob
The possible problem is what do you do if you destroy your pulley while trying?
1) You need to use the car before you figure out another method to safely remove it
2)now none of the other pullers will fit over the pulley
3)If you are not pulling it straight off you can possibly bend/distort the shaft
4)are you in a gambling mood?
Old Jul 5, 2006 | 09:13 PM
lol
You guys do what you want, blowing money on useless tools that you dont need to finish the job.
My pulley install cost me under 100 dollars out the door.
That tool is doing what its supposed to do, removal of pullies, steering wheels or gears. You guys are just used to being raped and tricked into buying a tool you dont need.
Old Jul 8, 2006 | 11:46 AM
bdog1's Avatar
bdog1
i FINALLY HAD SUCESS WITH A PULLER DESIGNED FOR PULLING TIE RODS. BEEPIER THAN THE 3 JAW GENERICS AND ONLY 2 JAWS FOR EASIER ACCESS. THE ORIGINAL PULLEY WASN'T USABLE AFTER THE DUST CLEARED.
LIKE I'M GONA PUT IT BACK ON ANYWAY.. RIGHT!
Old Aug 19, 2006 | 10:34 AM
british kompressor
Well, to close this thread off I would like to share my pulley swapping experience from last night.
So, the 3 arm puller had to be converted to a 2 arm puller because I did not want to lift the engine higher. We applied enough pressure to start warping the pulley and left it like that. I then took a small propane torch and started the heating process. After about 1 minute I heard a loud bang, and the pulley was unseized. We kept pulling and it came of smoothly after that
So, other then being very careful with the torch, it was pretty straight forward.
As for the performance gains, I’m not very impressed. I noticed the difference but it was no dramatic. A passenger who rides along pretty often with me could not notice the difference. It's not bad but its way too overrated on this site.
Old Aug 19, 2006 | 12:00 PM
DarkMiniCooperS's Avatar
DarkMiniCooperS
Get a "genuine" puller tool...
It is well-worth the $$ (especially for free when rent from Webb, or 20$ fro Alta).
I bought one and lend it it many people back in Montreal.
The last think you want to do is to ruin your supercharger's shaft using crappy tools...
Old Aug 19, 2006 | 12:39 PM
british kompressor
well, the tool is pretty much designed for that purpose and I have to say it worked rather well. I just wanted to let everyone know that you really dont need the special tool.
By the way, do you know of any "track days" happening in the montreal area?
Old Aug 19, 2006 | 12:51 PM
DarkMiniCooperS
Contact Biimmershop for Mtl's track events....
www.bimmershop.ca
willymcd's Avatar
willymcd
I just did mine too, installed the madness 15% pulley and changed my oil, i rented their puller and it worked great, really great. Did you find it a pain to release the belt tension, ugh mine was a b!t$h, spent forever trying to release the tension!
I noticed a difference, mostly the added torque. but the gain wasn't that great as you said! i think it needs a cai to compliment the pulley. I was planing on making a intake but i don't think i have enough time anymore, i have to leave for school and leave behind all my cool shop tools. Might just buy the madness intake, or maybe the alta, haven't decided yet.
Old Aug 19, 2006 | 12:52 PM
DarkMiniCooperS
You might also want to visit MontrealRacing for more track infos...
http://forums.montrealracing.com
bahman
Feb 14, 2016 10:29 AM
Debi's Coop S
Oct 3, 2015 08:19 AM
fkrowland
Sep 30, 2015 10:30 AM
audio131
Sep 28, 2015 02:21 PM
daviday
Sep 25, 2015 01:31 AM
