Rust :: door sill area of '02-'05 MINIs
Old Jun 2, 2006 | 07:33 PM
  #201
34Mini's Avatar
34Mini
Yep... my early '05 is showing a tad of rust under there... Time to paint and make sure I dry there!
Old Jun 4, 2006 | 09:03 AM
  #202
DJA's Avatar
DJA
Rust
(This was moved over from the Mini Talk forum)
Has the concern over the door sill / weatherstripping rust died down or is it not an issue for most people? Seriously, as someone who is considering this car, I read the posts over at MotoringFile and it's very much a concern for ME. The idea of non-damage related rust on a ONE YEAR OLD car is something I have extreme difficulty accepting. Even though it is just under weatherstripping in a door opening, it is still unacceptable.
I live in the snowy/salty Northeast and I keep cars long-term. Everyone has there own tolerance level I guess, but I would be VERY upset...
http://motoringfile.com/2006/05/31/h...-rust-problem/
Old Jun 4, 2006 | 09:09 AM
  #203
Minitee's Avatar
Minitee
I'm not that worries about and I'm just taking delivery of my new MINI very soon. A known problem is a problem you can plan and prepare for. I don't like the fact of the rust and I'm disappointed, but its not enough to sway me. Hopefully MINI USA handles the problem in a customer-focused way. If they handle this with denials, then I'll be concerned about a systemic corporate value of ignoring the customer. More GM than Toyota, if you will.
Old Jun 4, 2006 | 10:37 AM
  #204
kenchan's Avatar
kenchan
not an issue on mine... nor is it an issue on shukes24's car which has been
in service in michigan as a daily driven car.
i recommend monitoring it on occasion and just clean, touch up, etc.
if you're worried.
you just pull the stripping up and just push it back on the rail after inspection. anyone can do it.
Old Jun 4, 2006 | 12:14 PM
  #205
mct's Avatar
mct
Originally Posted by Gabe
Apparently my post on MotoringFile is taken the wrong way by a few people. I mean no disrespect by using the term "mass hysteria". In fact I stand by my claim that it is hysteria. It just also happens to be a huge potential problem. Calling something hysteria doesn't mean it's not a real problem. I was just trying to convey the sense of urgency and emotion that this issue is generating.
Now for the real reason of my post:
If anyone would like to send their rusty MINI pics to me for a little MotoringFile project I'm planning, email them to gbridger@gmail.com with the build date and whether or not you've installed an aerokit. I can guarantee a few folks at MINI will see them.
And a little photo tip: For close-up shots make sure your camera is set to macro mode.
Gabe - is there a reason they need to know if you have an aero kit? Are they thinking if you have an aero kit your are more prone/less prone to this problem? I just picked up my new 06 MCS 2 weeks ago with VDC-installed aero kit and am just wondering.
Old Jun 4, 2006 | 01:18 PM
  #206
Gabe's Avatar
Gabe
I was told that any installed of parts in that area would need to be documented when looking at the issue. Not saying that it is a cause. Personally I don't see how that would be an issue.
Old Jun 4, 2006 | 02:40 PM
  #207
volki
I wish I had to join NAM for a more enjoyable reason, but here is the first post...
Below are the pictures of mine (also sent to Gabe). The car is an 03 (4/03 built) MCS without areokit.
Although it seems to be at an early stage, I have rust on both sides. It is VERY tempting to just scrape it and do something about it, but I know that I must wait for an "official" repair from MINI.
For what it is worth, the car was washed about 2 weeks ago, and like in every other case, when I removed the strips, the area was wet. I keep it garaged all the time and dont wash it very often.
I am trying to set up an appointment with the MINI field service engineer for the clutch; I will be sure to show him the rusted parts along with the print out of this thread.
Good luck to all of us!!!
Old Jun 4, 2006 | 03:28 PM
  #208
DJA's Avatar
DJA
Another concern for me is the idea that this area shouldn't rust (especially after one year) even if it remains wet for long periods. There are many areas of a car that trap water (fender liners, mud flaps, moldings, etc) and they normally do not rust. Aren't these cars made with fully galvanized steel? Shouldn't they have elastomeric waxes and coatings in water prone areas? The fact that this seam area is rusting seems like a manufacturing defect. The finish of these edges looks remarkably crude.
If it's happening in this easily accessible area, it may also be happening around glass frames or any hidden edge areas....
Old Jun 4, 2006 | 04:23 PM
  #209
MINIclo's Avatar
MINIclo
7th Gear Gal
Merging this thread with the Rust on the 02 sticky in the Beneath the Bonnet forum.
Old Jun 4, 2006 | 06:30 PM
  #210
agranger's Avatar
agranger
I pulled the door seals on my 2006 (Yes! A Two Thousand and SIX) MCS and found a few rust stains, the most notable documented here:
MY CAR IS 6 MONTHS OLD - I PICKED IT UP ON DECEMBER 16, 2005!
I took a piece of auto grade sandpaper and it brushed right off... I didn't even go through the layer of paint. I then applied a liberal coating of P21S carnuba. I'm not sure if it will help, but I'd bet it won't hurt!
I know that this is a tiny little superficial rust spot. I'm not freaking out about it... I'm just not happy that I have to think about this with a brand new car.
MINI: To spare the embarrasment of any fair person, I won't tell you which finger is pictured above!
Old Jun 4, 2006 | 06:55 PM
  #211
Tarzan's Avatar
Tarzan
Well, there's the perforation...
Old Jun 4, 2006 | 07:43 PM
  #212
inimmini's Avatar
inimmini
12/04 build
My early '05 has a couple rust spots on the passenger side. One at the top of the seam, and another further down. Like some one else commented, even if this area is always wet, why is it rusting in a year and a half? Also, I can't figure out how so much water is getting in there. The holes in the side don't actually go thru to the seam. The root cause of the rust, though, seems to be this seal. Even if the dealer were to fix this little bit of rust, no doubt it would be back again soon unless the rubber seal is re-designed.
Old Jun 4, 2006 | 08:47 PM
  #213
DJA's Avatar
DJA
The right forum?
Shouldn't this discussion be held under the more widely visited Mini Talk section? Although it is just gaining momentum, this has the potential to hurt sales, reputation and resale value. It can possibly impact every current mini owner. This should be available where the most people will see it.
This is a little bit of rust now, but it is a big deal if you paid the premium demanded for this car. It also should be a big deal for BMW, and the more people who demand resolution, the better the chance of a fix for current and future owners.
Old Jun 4, 2006 | 09:37 PM
  #214
caminifan's Avatar
caminifan
Presumably, Gabe is referring to the full Aero kit (including the revised side trim pieces). If you only have the Aero kit front bumper, I doubt that you need to mention the Aero front bumper, right Gabe?
Old Jun 4, 2006 | 09:38 PM
  #215
caminifan's Avatar
caminifan
Clo, a VERY GOOD idea (to merge the threads)! Nothing like having multiple threads to confuse/diffuse the issue.
Old Jun 4, 2006 | 09:45 PM
  #216
caminifan's Avatar
caminifan
Where is the perforation? I see some bubbling that has broken the plastic/cellophane tape that was placed over the unpainted area, but not a hole in the sheetmetal (which is the general standard for perforation). Depending on what MINI says about whether they will cover a repair to the bubbling (as well as whether the rust warranty has lapsed), the bubbling should be treated with dilute phosphoric acid and painted with a rust preventive primer. Otherwise, the bubbling will lead to perforation (and rust cancer after that).
Old Jun 5, 2006 | 01:01 AM
  #217
Brihyanna's Avatar
Brihyanna
sly:
My 03 has rust! Erk... Will have it documented I guess at the dealer and send pics/VIN.
Just a thought, even if you had the rust check thing every year (or as required), would they even check under the seal?? Doubt it.
Old Jun 5, 2006 | 04:37 AM
  #218
Newdl's Avatar
Newdl
Murphy's Oil Soap
Originally Posted by chows4us
I finally checked ... nothing ... painted perfectly and the paint looks excellent. The passenger side WAS damp, not drivers side.
I wonder if some WD40 in there would help since the primary purpose of WD40 is to displace water?
WD-40 literally stands for Water Displacement, 40th attempt. That's the name straight out of the lab book used by the chemist who developed WD-40 back in 1953. The chemist, Norm Larsen, was attempting to concoct a formula to prevent corrosion -- a task which is done by displacing water. Norm's persistence paid off when he perfected the formula on his 40th try. http://home.howstuffworks.com/question155.htm
I heard somewhere along the way that Murphy’s Oil Soap, when applied will act as a temporary rust inhibitor....Hate the fact that I even have to think about this after 1 year of ownership...but hey...guess better now then later!
Old Jun 5, 2006 | 07:39 AM
  #219
kapps's Avatar
kapps
That's what I was wondering too. I'll probably talk to my SA this week and see what/if they will do anything.
Old Jun 5, 2006 | 09:35 AM
  #220
Merkursport's Avatar
Merkursport
Just checking in: 03 MCS, ~38k miles, originally delivered in Illinois, daily driven year round in Michigan -- no rust either side. Interesting knowing about this potential rust issue and will keep an eye on it.
Old Jun 5, 2006 | 10:11 AM
  #221
volki
Originally Posted by caminifan
Where is the perforation? I see some bubbling that has broken the plastic/cellophane tape that was placed over the unpainted area, but not a hole in the sheetmetal (which is the general standard for perforation)...
That's what I saw and described as well... If you look closely, there is a tiny bit of thin metal that connects the two sheets, and there is the tape that covers the whole unpainted area. The rust is superficial on that thin metal and bubling at the moment. As I said, I am very tempted to do something about it...
Old Jun 5, 2006 | 10:23 AM
  #222
okraD La's Avatar
okraD La
Took the car in this weekend and of course, the MINI guys weren't there...Had to deal with the BMW people (BMW shares space with the MINI dealer I go to.)...Of course they are unaware of the issue...
Will check in when I get the MINI gang to look at it...
Old Jun 5, 2006 | 10:37 AM
  #223
DJA's Avatar
DJA
I would be tempted to fix it too. But it is smarter to wait until BMW makes their plan clear. Remember, this just came to light several weeks ago and it will take time for BMW leadership to get the message and decide how to handle this. This could be costly for them in both money and reputation.
But, if you mess with the "integrity" of that edge, you will be giving your dealer the option of saying it was all your fault.
Old Jun 5, 2006 | 10:51 AM
  #224
BigBrownDog's Avatar
BigBrownDog
Looked at mine yesterday - 2005 built in 3/05 - both sides were fully painted. Drivers side had a bit of moisture inside, passenger side was dry. On the driver's side, there was a smidgen of a rust stain along the very top of the seam, maybe 1-2 cm long. No bubbling or anything else. Almost looks like a transferred stain from something else (is there metal inside the rubber seal?).
Old Jun 5, 2006 | 10:56 AM
  #225
caminifan's Avatar
caminifan
One thing you could do is to notify MINI/BMW in writing as soon as possible (like certified, return receipt so you can prove they received the letter). And then follow-up (again, certified return receipt) maybe every two weeks. After three attempts, you are kind of in the three strikes zone and if you don't get any action out of MINI/BMW, you have laid the foundation for a claim that they blew you off and you had to act to stop things getting any worse. The current bubbling is not that severe and if stopped, the rust issue has gone away. I don't know what MINI/BMW will do about this. They (MINI/BMW) are more interested in selling new cars rather than extending the life of cars they have already sold.... I personally would fix the rust while it is a minor issue. But then again, I obsess about my cars more than normal.
