Disadvantages of 15% Pulley?
Originally Posted by mdsbrain
See post #3 please
Originally Posted by skankrabbit
The stock pully isn't bolted on, it's held on by pressure. To get it off you need to use a tool to yoink it off the shaft, which yoinks it off straight as not to bend the shaft. As to what happens with it... it's makes a pretty good paper weight.
To put it back on you need to heat it up (>350 degreesF I've heard, thus expanding the metal), and forcing it on. A PIMA if you ask me.
Most aftermarket pully companies have come up with a hub that sits on the shaft and allows you switch out pullys with bolts.
Why go back to 0%
So, if the only result in installing a 15% pulley is improved performance, improved driving style and in some cases improved gas mileage (except for instances involving different user behavior:-)...why would anyone ever want to go back to stock or install a 0% pulley?
I'm pretty conservative when it comes to tampering with car mechanical infrastructure and have pretty much been convinced (thanks to all of the helpful posts) to make the switch to a 15% pulley but am curious as to why someone would do this and make the decision to go back to 0%...are there other disadvantages or problems with 15% or higher % pulleys that would cause someone to go back?
Thanks,
Miles
Thanks,
Miles
fkrowland
Sep 30, 2015 10:30 AM
daviday
Sep 25, 2015 01:31 AM
