Rattle in my dash Board
Old Apr 13, 2007 | 05:14 PM
  #26
dave's Avatar
dave
pug poo picker-upper
On the 05/06 dash, yes, you need to remove the a-pillar trim (interior) to remove the top of the dash.
Old Apr 13, 2007 | 05:56 PM
  #27
Pendergast's Avatar
Pendergast
05 MCS Dash Rattle That's Really Loud
Post #122 of the above link lists Service bulletins that cover this problem. You guys should check that thread out. It shouldn't cost anything for the fix. Actually I'm having the dealer fix mine over the next couple weeks while other body work is being done. I hope it works.
Old Apr 13, 2007 | 07:02 PM
  #28
billie_morini's Avatar
billie_morini
a rattle in the dash board may be better than a rattle snake in your dash board
Old Apr 13, 2007 | 07:45 PM
  #29
chuckt's Avatar
chuckt
Well that stinks. Fortunately I didn't need to take it completely off. I was able to get a piece of foam under the vent by just lifting the drivers side up a bit. I'll go for a cruise tomorrow and see if it's fixed. The lip on the dash pad that goes under the A-piller trim did pop out, but I was able to coax it back into place by sliding my ID badge under the front of the trim & pulling back to flip it over the dash pad. It took quite a bit of pushing/pulling on the pad until I figured out what to do. After that it was a breeze.
Thanks Dave.
Old Apr 13, 2007 | 07:48 PM
  #30
chuckt's Avatar
chuckt
Yeah, I know they'll take care of it, but I don't plan on taking it in, unless I absolutely need to. My dealer is about 90 miles away.
  #31
chuckt's Avatar
chuckt
Old Apr 14, 2007 | 07:59 AM
  #32
Pendergast's Avatar
Pendergast
Same here. That's why I put up with it for a few months.
Old Aug 21, 2007 | 05:49 PM
  #33
dubsdj's Avatar
dubsdj
My dash had an awful rattle and creaking noise when steering especially at low speeds.
Had the steering column replaced under warranty and that helped the creaking noise a bit, for the rest I just rolled up a duster cloth and wedged it along the gap between the windscreen and the dashboard. I put the cloth about 2 inches to the right of that circle thing whatever it is... But if you are left hand drive I guess it would be 2 inches to the left of that thing.
Old Aug 21, 2007 | 06:41 PM
  #34
YakiMini's Avatar
YakiMini
Good Call! I'll have to try that!
Thanks!
Old Oct 3, 2007 | 05:21 PM
  #35
fixitgarage's Avatar
fixitgarage
Originally Posted by lambspeed
I have a horrible rattle in my dash also. It seems to be coming from the very front by the windshield. If I hold one finger on it, it goes away. Seems to only rattle when its cold and very low humidity.
I had the same rattle I fixed it by putting a small amount of oil between the upper windsheild molding and the body.
Old Oct 4, 2007 | 04:13 PM
  #36
mac020's Avatar
mac020
The windshield guys fixed mine.
Old Oct 7, 2007 | 09:39 AM
  #37
ruftec's Avatar
ruftec
Annoying Sound!
Hello all,
Has any one here experienced a loud sound while driving past 90 mph?
The sound is best described as putting a sheet of paper between your lips and blowing. The faster I go, the louder the sound. The sound seems to be coming from the front center dash area. Pressing on the windsheild or dash while the sound is present makes no change.
How do I even explain this to the dealer? They aren't going to exceed this kind of speed.
Thank you,
Jo
Old Mar 21, 2010 | 01:46 PM
  #38
Zippymcs's Avatar
Zippymcs
Dealer Quote
This darn dahboard rattle in my '04 S is driving me nuts; it happens when it's cold and it stops if I just press the dash lightly. I'm not sure I want to try to repair it myself, but the dealer quoted me $1,000.00 to fix it! How difficult and time consuming is this to DIY? Thanks. Robert
Old Mar 21, 2010 | 04:21 PM
  #39
mac020's Avatar
mac020
I never owned car with so many rattles! I just learned to put up with them when the Chicklet box is empty.
I had the exact same rattle. Very annoing! Only when it was cold though.
To tried to get rid of the rattle you describe, more like a loud clicking. I removed the dash board and glued some felt around all the mounts. It didn't help!
Actually there's a pin dead center in the car behind the windshield. It holds the superstructure to the frame. The only way to get to it is through the opening. You prolly need to wait until you replace the windshield in order to get to it. I taped a note to the dash so I wouldn't forget.
Now I'm working on the rattles in the moon roof and hatch. Any help on these would be appriciated.
Old Dec 10, 2012 | 11:33 AM
  #40
astroBlackMetallic_Mini's Avatar
Originally Posted by 1FSTMINI
No problem ....Lemme know if you need other instructions.
hey, any chance you have any of those pics for ripping out the dash of an 06 cooper? i have some hidden rattles still, driving me crazy. 2 hours of no results removing dash! help! lol thx
Old Dec 17, 2012 | 10:13 AM
  #41
found it. it was the auto AC sensor.
Old Dec 17, 2012 | 10:10 PM
  #42
BMBULBE's Avatar
BMBULBE
Make sure the rattle is actually inside your dash. I had an Ipass transponder mounted high up near the rear view mirror in a suction cup mounted bracket that occassionally rattled against the inside of windshield. However, the sound traveled down the windshield and seemed to me and others that it was originating inside my dash. I was convinced the rattle was inside the dash. I had an appointment to have the dash ripped out. However, by happenstance I was wiping the inside of my windshield, my cloth swiped against the side of the transponder, and I heard the rattle.
Jim Ferrell
Oct 6, 2015 08:09 AM
Oct 1, 2015 12:34 PM
Oct 1, 2015 12:28 PM
Oct 1, 2015 12:13 PM
