pulling to one side or the other while in gear? also noise from rear when breaking?
Old Sep 27, 2005 | 08:33 PM
willymcd's Avatar
willymcd
i have a '05 MCS with LSD and i have noticed that the car, while in gear accelerating and coasting, will pull either to the left or the right, more to the right on flat surfaces, and pulls a bit harder while under acceleration. when i take the car out of gear and coast in neutral the car tracks perfectly straight.. is this normal? is this just torque steer, if so why does it pull to one side while under no acceleration??
another question, when i am stopping and first the initially step on the break i hear a clunk noise from the back wheel area, almost as if the rear break caliper was loose and was being pushed forward from the applied break pressure... this is not the exhaust popping either. is this a normal noise, i am thinking not, but just curious to see if anyone else hears a thunk from the rear end when breaking?
Old Sep 28, 2005 | 09:00 AM
betet's Avatar
betet
I wonder if the "pulling to one side" is a common problems w/ the new MCS...
Check out this thread
https://www.northamericanmotoring.co...ad.php?t=51067
Not sure if the same problem as yours.., or is it even a problem..
///Gilbert
Old Oct 3, 2005 | 11:08 PM
MINIAACK's Avatar
MINIAACK
I have an 03 that does the same exact thing. even when just cruising it pulls mostly to right. even when decelerating but in gear. If in neutral tracks straight.
Old Oct 4, 2005 | 05:20 AM
betet's Avatar
betet
MINIAACK
Here are some reasons why it can be doing that..
1. low tire pressure
2. need alignment
3. ripped OEM camber (hopefully not mushrooming)
Have everything checked...
///Gilbert
Old Oct 4, 2005 | 05:06 PM
MINIAACK's Avatar
MINIAACK
Tire pressure is even. Alignment is also fine. When coasting in neutral, car is straight as arrow.
Old Oct 4, 2005 | 05:21 PM
Battle Cattle's Avatar
Battle Cattle
BTW MINIs dont have torque steer... equal drive shaft lengths, well in theory they dont, but mine has ever so small to the right...
-Josh
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
maestro39
Oct 27, 2015 02:38 PM
cm.d
Aug 19, 2015 08:51 AM
minipopkart
Aug 13, 2015 05:22 AM
