how many cracked upper strut mounts?
Originally Posted by marco621
...Can anyone see from the pictures if there has been mushrooming? I spoke the tech and asked if this was covered under warrenty and he said that he'd have to check it out to see how severe it is. If it's badly cracked he explained that it will be taken as the vehicle was abused and will not be covered on warranty.
The claim about abuse is a bit of a reach. I would take the car to another dealer that is not as hostile. What constitues the abuse test? - the presence or absence of mushrooming? I would like for them to explain that to a Small Claims Court judge....
Thanks for the Information
Just checked my GP after I heard about the "mushroom" issue (now that MTTS is over) and I'm glad to know about the information in this thread so I can keep an eye on this. My MCS is smooth and flat on both towers, the driver's side on my GP has a small "crease" upwards in one area, I'm going to check that out further.
GoodFinder
GoodFinder
Join the club
After reading this long thread, I decided to check my 06 MCs, @#$%^&* a b#$%^ch, my driver side mount has a crack. I cannot believe after just 1600 gentle miles, can't remember hitting any big potholes, the mount is shot. I guess I will need to contact the dealer. Is this a sign of worse to come if left alone? Thanks.
My Question is: Does the fix alleviate the problem of mushrooming? I have an 06 on order being built at this moment. I want to get things figured out and setup before I get the car. I will hit bad roads the first 1 minute after I drive it. I could go for an m7 plate system if they solve things or are beneficial to the new design as well.
If this cant be fixed I might refuse the mini at the store. I dont want to spend 26k on a piece of crap.
The way I understand it, the SRP is for stengthening the strut tower, not the rubber strut mount. One potential solution would be going with aftermarket pillow mount that ultilizes polyureathane (I guess I spell it right). In my mind, only some sort of trianglate plates jointing (from underside) the top and inner sidewall of the tower area can strengthen the tower. Of course, that's easy said than done, as there's no room for such mod when the strut assembly is installed.
I have an 06 and I drove it with TLC for 1600miles. The only thing I have done is to make high speed turn on a few occasions. The other thing I can think of is going over a couple bumps on the driver side at slow speed, although it felt like flying due to stiff suspension. No major hit to suspension at all!
If it doesn't progress any worse, I will leave mine alone. It is very disappointing nevertheless.
I think the mushrooming would be much worse in repairing and costs than the strut thing cracking. Would you advise getting the m7's right away? I am not a mod person but this realy isnt a mod its a possible saving thing.
also, i bought a road machine to be a road machine. I dont want to treat it like it's a pansy machine. There are bumps around here on a regular road that I dont even consider a real pothole that would make anyone with 17 inch rims cry. This is much more of a serious issue in NYC.
well, I am not getting the 17's. I wish I could swap for someone's 15's to be honest. If anything ever cracks im going straight to 15's and more tire/air bounce. the standard S 16's with runflats arent the best but they are free which is neat.
Poll on strut mount failure - please respond....
To all that have experienced the dreaded strut mount failure (and/or mushrooming), there is a new thread/poll at:
https://www.northamericanmotoring.co...ad.php?t=78629
Please participate in the poll. Thanking all those who participate in the poll in advance.
Originally Posted by caminifan
Mushrooming is most likely to occur once the strut mount has cracked. The elasticity of the mount has been compromised (by the crack) and the forces that would normally be absorbed by the strut mount are transferred to the sheetmetal. Net, net, if your strut mount has cracked, get it replaced. The longer you dither (in replacing it), the greater is the chance that mushrooming will start.
Originally Posted by Kentiki
I noticed this on my strut mounts: Lots of a clear oily substance, on one side only. What could this possibly be? I don't see any cracks.
Does the m7 STB stop mushrooming?
Originally Posted by Dave
They are a major major improvement over the stock set-up and you shouldn't have any deformation of the sheatmetal of the body (mushrooming) once they are installed.
Originally Posted by hong
even on a newer 2006 model?
His question was about the mushrooming. For my piece of mind I would not rely on MINI's 2006 strut mount change to remedy the mushrooming problem since the strut tower and the load path into the strut tower is still essentially the same as it was on the 2002-2005 MINIs.
Therefore, to prevent mushrooming, even on a 2006, I think the reinforcement of the strut tower makes sense. I have the strut reinforcement on my 2006 MINI (which I run in combination with camber plates).
I know some of you have mentioned having problems with getting OEM replacements under warranty. I was expecting this with mine, but Crown Mini in Richmond, VA replaced it without a question. Overall, I have had great luck with the guys over there.
[quote=Dave]The change on the 2006 was to the strut upper mount, not the tower itself. That change appears to have been made to address the cracked upper strut mount problem. [quote]
Sorry Dave, 06 still has the rubber mount problem. I just found a slit (crack) on my driver side (see pic posted above). I am deciding whether to take it to dealer or not.
Hopefully the '06 strut mounts at least prove to be "better" on average over time, even if they aren't "fixed."BTW, all I was trying to point out above was that MINI changed the strut mount, not the tower, so mushrooming still remains a concern.
