Oil Pressure Gauge Sender
Old Apr 29, 2005 | 07:54 AM
  #26
SumWon's Avatar
SumWon
Originally Posted by Greatbear
Another good area to mount the oil temperature sender is in the end of the oil filter canister
Great info! Is the oil filter before or after the oil cooler on the MCS?
Old Apr 29, 2005 | 04:45 PM
  #27
norm03s's Avatar
norm03s
GreatBear those are good points
So, temp. sender in filter canister and pressure sender and OEM sender in T on engine block.
Old Apr 29, 2005 | 05:13 PM
  #28
Greatbear's Avatar
Greatbear
Moderator :: Performance Mods
I believe it's before. Pan => pump => filter => cooler => engine oil galleries.
Old May 1, 2005 | 03:17 AM
  #29
Cooper S IRE's Avatar
Cooper S IRE
a little bit off topic but does anybody know the thread size of the sump oil drain plug want to fit a temp gauge and wanted to have the right fittings
Old May 4, 2005 | 06:23 AM
  #30
steebo777's Avatar
steebo777
Originally Posted by MSFITOY
Could you elaborate on this part? What size/type is this fitting? Thanks:smile:
Sid, let me know if you want to see this on my MINI as I can show you exactly what I did and the parts needed.
Old May 4, 2005 | 07:29 AM
  #31
SumWon's Avatar
SumWon
I would be interested as well. Will you (and your MINI) be around at the chili cookoff Friday night?
Old May 4, 2005 | 01:27 PM
  #32
NeilM's Avatar
NeilM
I can't answer that question, but would like to bring up a related point. The drain plug oil temp senders are made of fragile brass and have to be torqued to a rather low value: just 11 ft-lb in the case of the VDO sender I installed several years ago in my M3. There's a pretty good risk of it getting over-torqued and broken unless you do all your own oil changes - and maybe even then!
For that reason I eventually relocated mine to an oil distribution block at the oil filter housing. Although it's now not really in a moving stream of oil - more like a backwater - the typical temperature readings haven't changed, rather to my surprise.
Just something else to consider when planning.
Neil
05 MCS
96 M3
Old May 4, 2005 | 02:03 PM
  #33
Cooper S IRE
Neil
05 MCS
96 M3
exactly why i wanted to install a tee piece and a fumoto valve
where did you tap into exactly for the oil temp
Old May 5, 2005 | 11:05 AM
  #34
NeilM's Avatar
NeilM
On the 05 MCS I have the factory chrono Pack, so the sender is wherever Mini put it (I haven't looked yet).
The oil distribution block I installed on the M3 fits on the back of the oil filter housing using the existing tapped hole for the stock oil pressure warning switch. The distribution block provides mounting for both oil pressure and temp senders.
Neil
05 MCS
96 M3
Old Jun 11, 2005 | 09:30 PM
  #35
HAIGHTD's Avatar
HAIGHTD
ProMini or HomeDepot??
After looking at this thread and the great photo of the ProMini adaptor, I too will be making a little detour to HomeDepot for a 2" male-male adaptor and an all female tee...thanks guys for another great thread
Old Jun 12, 2005 | 07:04 AM
  #36
MSFITOY's Avatar
MSFITOY
PMd you Steebo:smile:
TREX
Nov 2, 2019 07:31 PM
Tylerlanger1
Aug 21, 2015 03:03 PM
finn
Aug 21, 2015 07:59 AM
JamJam43087
Aug 16, 2015 02:02 PM
