Ticking noise at idle
Fellow NAMers,
I noticed a ticking noise when I was warming my 02 MCS last night. It makes this ticking noise just at the point that the engine is warmed up. It does it at lower idle speed. It does not at warm up idle. Has anyone experienced this weird noise?
ARLY
ARLY
Originally Posted by Arly
Fellow NAMers,
ARLY
ARLY
Tick...yes
Mine ticks sometimes, too, upon start-up. Very faint, yet noticeable. Goes away after driving a bit. 27,000 miles on my 2003 MINI CVT. I don't think it's anything to worry about.
-boognish
-boognish
The ticking comes from the engine valves
It happens because it takes time for the oil to travel upwards to fill the lifter and the gaps between the cam and lifters. It occurs more often we you strat the engine after it has been off for a while.
If the noise is extreme you might need adjustment otherwise think of it as old age ticking in
There are two different emissions control devices that sometimes come on during warmup. One is the canister purge solenoid that will make a rapid 'tickatickatickaticka' sound at a fixed frequency. The other is the leak detection pump near the fuel tank which makes a slow 'tick-tock' sound for about a minute. It could be most likely the former device. Neither one of these are affected by engine rpm around idle.
MCSs can also encounter a bit of 'rotor rattle' at certain rpms. This is not a cause for concern either, just the nature of the beast. Some cars have a pronounced transmission rattle as well that goes away when the clutch pedal is depressed.
I have an '04 cooper S with the 6 speed and have noticed a random ticking when I just begin to move out in first gear. It is noticeable with the driver's window open but not so much from the passenger's side. It isn't rythmic at all and sounds metallic or maybe like a relay? Not sure if this is the same thing or not, but I would like to know what causes it too.
had the issue
Mine recently started ticking at idle and low rpms. The noise was coming from the belt area. Took it to the dealership and they told me the belt tensioner needed to be adjusted and a new belt also was added becuase it was cracked. Now its fixed and there is no clicking or ticking just smooth engine noise
The Dual Mass Flywheel (DMF) has a tendency to make a ticking sound with the clutch NOT depressed. My MINI did it and it was most noted with the driver's window down but could be heard with the windows up. I had the DMF and clutch replaced at 27,000 miles, I can barely here it now, but Cassie is now at 46,667 miles. I believe there is a service bulletin out on this.
Try pressing the clutch to see if the sound goes away.
Good luck.
Good luck.
The ticking sound you hear at startup is likely the sound of the Leak Detection Pump located in the passenger rear wheel well cycling as the ECM commands the EVAP leak test; the test will not run if the fuel level is under 1/4 or greater than 3/4.
unxpectederror
Oct 22, 2015 12:16 PM
