HELP Mini Stalls on Sharp Turns....
Old Feb 26, 2005 | 08:10 AM
Gdrougas's Avatar
Gdrougas
PLease help....I have an 02 MCS The best car I've ever been in. However twice now when I take a sharp corner the car shuts off and the electrical system gets a little wierd.....like everything resets, Trip, Fuel Milage, etc. Anyone else have this issue or know anything about it. The only thing that I've added is a CD player and Amp but I do that for a living and I know the amp isn't drawing alot of power from the electrical....What do I do?
Geo-
Old Feb 26, 2005 | 08:43 AM
Cooper_Ski's Avatar
Cooper_Ski
Fuel Pump? I use to own a Ford Focus and pple were complaining that whenvever they would make right turns going onto on-ramps or taking right turns their cars would shut-off. (only happening when fuel levels were <1/2 tank) I'm just speculating that it could be a fuel pump issue.
Old Feb 26, 2005 | 08:51 AM
rataha's Avatar
rataha
02 build. Could be the wiring harness do you still have warranty?
Old Feb 26, 2005 | 10:48 AM
kenchan's Avatar
kenchan
steering pump?
Old Feb 26, 2005 | 04:19 PM
Gdrougas's Avatar
Gdrougas
Yeah Everything is under warrenty. Going in for surgery on Friday. How depressing. Anyone around the Mass area BTW? Thanks for the Help I'll let you know what it turns out to be.
G-
Old Feb 26, 2005 | 04:40 PM
GBMINI's Avatar
GBMINI
Lots of MINIs in Massachusetts - say "Hi" in the MINI2 New England forum; Are you going to MINI Peabody for service?
You mentioned the trip / fuel mileage / etc going "wierd" too - resetting? I wonder if you have a loose battery terminal, or a loose chassis strap between engine & chassis ...
Old Feb 26, 2005 | 07:29 PM
iamwiz82's Avatar
iamwiz82
I'd say it's one of the following:
1. Goofy fuel tank is starving your fuel pump
2. There is a short somewhere that is only contacting metal on right turns
3. Loose battery cable.
Old Feb 27, 2005 | 07:41 AM
MiniMe05's Avatar
MiniMe05
Sounds like a loose ground or possibly loose main wire harness.
xpunisherx
Aug 10, 2015 10:50 PM
ludedude
Aug 10, 2015 07:16 PM
Aug 10, 2015 01:59 PM
bc219
Aug 10, 2015 11:22 AM
