r5 power steering electrical connectors
Old 10-25-2023, 01:47 PM
mike_miniman's Avatar
mike_miniman
mike_miniman is offline
Hi - I was not careful enough removing the front subframe last week, (2013 MCS) and damaged one of the three plastic electrical connectors on the power steering actuator...specifically, the once closest to the center of the car. Now I cant seem to get the male part of the plug to completely connect to the female socket, and I have dsc inoperative issues, brakes will not hold for a hill take off, and steering angle indication through my foxwell scanner says -1105% or something like that.
I suppose I could replace the entire steering rack, but I'm trying to avoid that huge expense and significant labor effort. It doesn't look like the connector part is available on its own. So - I am hoping one of you really smart and helpful folks will have a brilliant and inexpensive solution to this...
The only other thing I have come up with is de-pinning the wires from the male connector and directly connecting them to their correct individual female connectors - there are 4. But then not sure how I'd seal it from elements.
Help! Thx in advance!
Old 10-26-2023, 10:16 AM
ECSTuning is online now
Received 1,974 Likes on 1,772 Posts
Hello,
So you can get the sockets.
https://www.realoem.com/bmw/enUS/sho...diagId=32_1668
2 Pin
https://www.ecstuning.com/b-genuine-...139145405~oem/
and
4 Pin
https://www.ecstuning.com/b-genuine-...138365356~oem/
If its on the rack side itself you would need to fix that and try to reseal it.
Otherwise its a new whole rack, JTEKT makes the racks for MINI.
https://www.ecstuning.com/Search/Sit...h/32106856876/
Here is the tool for repin
https://www.ecstuning.com/b-schwaben...ieces/ce-70-2/
MiniAP
06-05-2020 10:09 AM
Buckwdav
04-08-2019 07:16 AM
Steve Paepke
10-08-2010 02:39 PM
titi54
Classic Mini Talk
01-16-2007 03:59 PM
Miniphyter808
Hawaii
11
01-31-2005 04:41 PM
Quick Reply: r5 power steering electrical connectors
