R53 MT acts like clutched/neutral on ground, but normal if jacked up
Old Aug 20, 2023 | 02:49 PM
Luridiryx's Avatar
Luridiryx
Car: 2004 Mini Cooper S Manual Transmission
When on the ground: If I clutch and put the car in gear no power whatsoever and wheels dont spin. I can even put the car into gears without the clutch and there is no grinding.
When front end is on jack stands: I can clutch and put the car in gear and my wheels receive power normally, can rev etc. When jacked up if I try to put car in gear without using clutch I hear the grinding you would expect.
When returning car to ground after being jacked up: I can shift into first and creep around my driveway, but when turning off the driveway and giving a little more load it kind of goes straight into the neutral state described above.
Last edited by Luridiryx; Aug 20, 2023 at 03:23 PM. Reason: Allow more keywords in title
Old Aug 20, 2023 | 10:51 PM
Racingguy04's Avatar
Racingguy04
sounds like your clutch is toast. I have the exedy single mas flywheel in mine and i'm happy with it.
jmward2008
May 10, 2015 05:53 PM
spikfrank
Aug 1, 2012 09:48 PM
mscmagno
Oct 11, 2011 08:00 AM
remotecontrol
May 9, 2011 09:19 AM
mini4christine
Sep 3, 2008 05:02 PM
