Ran fine now Crank but no start...
Old Sep 12, 2023 | 05:51 AM
  #51
Jerry311sd's Avatar
Jerry311sd
Originally Posted by Daftlad
I do not have INPA or ISTA so I don't know for sure. Hopefully someone who does have it will weigh in...
I was able to reset the Airbag light with the INPA, The only light left is the Oil pressure light at idle, Im gonna replace the oil pressure sensor and HOPE that's the issue. I changed the oil the car runs smooth and quite. ayt 225K miles its very smooth no weird noise or smoking.
Old Sep 12, 2023 | 06:39 AM
  #52
Daftlad's Avatar
Daftlad
This happened on mine once. Flickered / came on at idle but anything above the light went out. Replaced the pressure sensor, end of issue.
Old Sep 12, 2023 | 07:05 AM
  #53
shrevemini's Avatar
shrevemini
Top Answer: 1
Either 3 things
oil pressure sensor
drain back plunger in filter housing
incorrect oil filter
Old Sep 12, 2023 | 08:23 AM
  #54
Jerry311sd's Avatar
Jerry311sd
Originally Posted by shrevemini
Either 3 things
oil pressure sensor
Well the sensor is next to the oil filter housing and i didnt see this issue before I changed the oil, so im going to put in a new filter and pressor sensor.
I'll order a new filter and do it this weekend.
Old Jul 24, 2024 | 01:23 AM
  #55
05mcstwin's Avatar
05mcstwin
HI Jerry,
by chance, do you still have your Mini and are you still in San Diego?
Old Jul 24, 2024 | 10:08 AM
  #56
Jerry311sd's Avatar
Jerry311sd
Originally Posted by 05mcstwin
HI Jerry,
I still have the car
I drive it once in a while, it will be for sale in a few weeks when i get back from romaina
Old Jul 24, 2024 | 07:33 PM
  #57
05mcstwin's Avatar
05mcstwin
I am in SoCal and had a similar issue, but I did figure it out. I am from the neighboring country, Moldova!
If youd like to meet up and exchange knowledge that would be cool. Shoot me a PM if youre interested.
Old Jul 25, 2024 | 05:40 AM
  #58
Jerry311sd's Avatar
Jerry311sd
Sending my stuff to the ECU Pros ended up fixing the car for a bit.
But now somtimes the headlights dont turn on the none of the light on the dash will come on (back light,blinker indicator,High beams) windows wont roll down or up. Then the next day everything works like it should. I'm done with the car and I dontthink ill ever buy another one. far to many problems with this thing.
ricardiini
17
Mar 27, 2026 10:33 AM
Juan Camilo Roldan
Aug 14, 2022 03:01 PM
AcidK1
Feb 10, 2022 11:03 PM
Adam Westbrook
Jul 4, 2021 12:30 PM
Valentin Bachellier
Mar 12, 2021 11:56 AM
