no crank or start
no crank or start
2006 MINI S with 170k miles.
This mprning, will not run.
All lights with key on, but just 3 clicks (solenoid?) no crank.
Full battery charge,
Hate to replace starter if there is another cause.
Thoughts or suggestions?
+1 for ground cables - starting in the battery compartment with the negative cable - but also check heat shield and make sure you don't have arcing from a loose one. But, at 170K could very well be the starter itself.
moorec614
Dec 13, 2016 05:14 PM
Lolo
Feb 12, 2003 09:57 AM
