Help!!!
Old Mar 18, 2023 | 07:49 AM
  #26
LooseR53's Avatar
LooseR53
This sounds like a possible culprit.
Bad alternator.
Tensioner strut broke>finished off alt.
Alt gave out> broke tensioner strut.
Seems logical.
Old Mar 18, 2023 | 09:21 AM
  #27
Daftlad's Avatar
Daftlad
What work has been done so far? When last we left this a number of parts had been ordered, have they been installed and is the knock now persisting afterward?
I ordered the ATI crank pulley@2%,15% boost pulley, the idler pulley, and ngk plugs.
I already have the tensioner hockey stick.
Ordered vacuum line as well.
My belt is brand new so I’m gonna re-use it. I read the stock belt is good for that setup.
Old Mar 18, 2023 | 10:05 AM
  #28
LooseR53's Avatar
LooseR53
Yes, under the second update noted in bold in the original post.
Old Mar 20, 2023 | 04:12 PM
  #29
LooseR53's Avatar
LooseR53
Guys, I have been updating my original post with the work being done and current issues. Please take a look at it again, I am still looking for advice. Thanks.
Old Mar 22, 2023 | 05:34 AM
  #30
LooseR53's Avatar
LooseR53
Well, I ordered the tensioner, water pump, gaskets, s/c oil, and the TPE charge pipe because I don’t wanna have to get back in there again.
If this doesn’t fix the car I’m going to brick the throttle and give her one last drive.
Old Mar 22, 2023 | 05:51 AM
  #31
Daftlad's Avatar
Daftlad
I'm throwing p1498 and 5E19.
I'm thinking belt tensioner next, then maybe the pipe under the S/C, and S/C service.
LMK what you guys think. Could the water pump be ticking? Might have to get that too.
P1498 not listed in Bentley but elsewhere on the interwebs indicates "post compressor unregulated air" as in intake leak; could be PCV line or something else; not going to be fun finding it
At this point would replace the tensioner - you don't need factory 'genuine MINI' (expensive) replacement just a good aftermarket like INA or Febi Bilstein. Then go front end service mode for supercharger inspection / service, water pump, fuel pressure regulator line, and crankshaft position sensor O-ring, plus if needed intercooler boots, pan gasket and lower engine mount "while you're in there." Fan resistor, hoses and lines as needed while the cooling system is drained.
Old Mar 24, 2023 | 12:20 PM
  #32
LooseR53's Avatar
LooseR53
Updated. Bump.
Old Mar 24, 2023 | 12:29 PM
  #33
Daftlad's Avatar
Daftlad
Replaced the belt tensioner. Still ticking. Going to try and get my other car running so I can tear into the supercharger soonish and take my time.
Guessing the P1498 and 5E19 are still there, anything others show up on the latest OBD pull?
Old Mar 24, 2023 | 12:49 PM
  #34
LooseR53's Avatar
LooseR53
I’ve been getting those two codes since I bought the car. The EML light randomly comes on too.
I haven’t checked for a bit. I’ll figure it out eventually, I’m just frustrated. S/C service/water pump is next, and I got the TPE pipe also.
Old May 1, 2023 | 09:02 AM
  #35
LooseR53's Avatar
LooseR53
The hose going from the valve cover to the intake was cobbled together from 3 different hoses and inserts at some point, and was cracked in multiple places. I'm replacing that hose.
I serviced the S/C, replaced the gaskets. It had plenty of oil in both sides, the gears were all mint.
I replaced the timing chain tensioner.
I'm doing the A/C clutch/bearing.
I also installed the TPE pipe. Don't 100% love the fitment on it, but its really close.
I'm waiting on the intake>right horn gasket.
Hopefully after all this she doesn't tick so loudly.
Old May 6, 2023 | 11:03 AM
  #36
LooseR53's Avatar
LooseR53
Serviced the supercharger, it had oil in it that looked pretty clean and there was still plenty.
Replaced the timing chain tensioner.
Replaced the water pump/inspected the gears they looked mint.
Replaced the A/C clutch.
The car is still ticking. It sounds like there’s small marbles in the motor. I’m about at my wits end with this car. It seems like maybe it’s internal to me at this point.
I’m unsure what to do next.
Old May 6, 2023 | 11:34 AM
  #37
Daftlad's Avatar
Daftlad
Edit: another thought is check upper passenger side motor mount condition, mounting bolts, and engine mount bracket bolts (4). Don't know why but the noise reminded me of that.
Thinking out of the box time. The noise doesn't sound engine rpm related, like bottom or top end. It sounds ancillary (belt driven) or even random, like something down below is loose, really loose.
Non-invasive:
>any difference in noise when you engage / disengage the air conditioning? As in compressor noise?
>any difference made when clutch pedal is pushed in (disengaged) or released out (in neutral)?
>Look under the car on a lift / jacks - engine mounts, transmission bolts, stuff hanging loose etc. Get the stethoscope again and start probing.
Invasive:
>would remove the belt, right side wheel well liner, rotate and shake every pulley in the radial and axial direction - crank, tensioner, idler, supercharger, alternator and AC for play. Recheck torque to spec on everything. If you've already done it, disregard.
>drop pan and look for things that don't belong there - metal bits, babbit etc that might point to (hate to say it) a wiped bearing(s) or internal damage
>front end service mode and pull the supercharger, look inside the top, check for excess play, rattling, things inside that don't belong there either
Might also be time to run it by a good, well -researched and trusted Indy mechanic in your area (not the Stealership obviously).
Other guys please chime in; our friend needs help!
Old May 6, 2023 | 05:45 PM
  #38
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
I've read this complete thread but may have missed something. The only video I see and hear sounds like knocking but the OP says it's "ticking". Big difference! If ticking, have you checked the Idler pulley? It's a simple, inexpensive but often overlooked item. To eliminate a whole lot of things, try removing the serpentine belt and start the car. ( You can run it off the battery for a short while without hurting anything.) If the ticking is still there, it's internal. If it quits, then it's something driven by the belt.
Old May 6, 2023 | 06:40 PM
  #39
LooseR53's Avatar
LooseR53
I”ve replacled:
- Belt tensioner
- Crank pulley (ATI 2%)
- Boost pulley (15%)
- Idler pulley
- A/C Clutch
- Alternator
- Serviced S/C
- Water pump
- Boost pipe (TPE)
- Timing chain tensioner
- Spark plugs
- Intercooler couplers
- Multiple Belts
So at this point everything on my belt drive has been replaced, aside from the s/c, but I inspected it. It seems to be in good working order. The rotors look ok and it doesn’t seem like there’s play. I’m pretty sure it’s internal.
I’m unsure if timing chain guides could be that noisy.
The throw out bearing is definitely making a little noise but it’s unrelated to this.
So lifters, rod knock, timing chain guides… I dunno.
Old Jun 11, 2023 | 05:57 AM
  #40
LooseR53's Avatar
LooseR53
Bump. Updated the original post. Car is fixed for now.
George DeXx
May 6, 2023 05:26 PM
sir_smackalot
Jun 15, 2013 02:42 PM
EMD20V
Sep 6, 2010 04:33 PM
TwistySister
Jul 16, 2008 04:22 PM
hechoenny
Jan 14, 2008 11:42 AM
