Mini not starting
Old Nov 29, 2022 | 10:22 PM
pitdoidaoR53's Avatar
pitdoidaoR53
Mini not starting
I have an r53 mini s. Car is completely stock. Just bought it from my neighbor its been seating for 7 years. I just put a new battery and new fuel pump , i removed all the old fuel and cleaned the tank. Added new fuel and car wont start. It does start with starting fluid, but when it wears off it dies down. So not getting fuel. Checked the fuel line coming from the tank and fuel does come out. Any help will be appreciated
Old Nov 30, 2022 | 06:35 AM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
Have you checked for codes with a reader? Where does the fuel come out? At the fuel rail? The injectors? Are you sure you seated the gasket at the fuel pump and filter correctly? The car won't run if you didn't. Simple thing: Check for corrosion and tightness of the ground wire in the engine compartment. If it's a bad connection, the car won't start.
Old Nov 30, 2022 | 08:06 AM
adriancl's Avatar
adriancl
Sometime R53 can't be started if the battery was removed for a long time.I advice you to do resync ECU , can use for that a cheap INPA diagnosis.Same thing when the battery is disconnected many times due to a defective steering pump -When steering pump run with key off.Need to resync ECU .
Old Nov 30, 2022 | 08:56 AM
pitdoidaoR53
Even tho it starts with starting fluid ? thank you ill try that tonight when i get home, ima order an inpa
Old Nov 30, 2022 | 09:29 AM
adriancl's Avatar
adriancl
Originally Posted by pitdoidaoR53
thank you ill try that tonight when i get home.
https://m.youtube.com/watch?v=fmsGdsZ2fpA
Old Nov 30, 2022 | 07:57 PM
dmath's Avatar
dmath
It's possible that you have air in the fuel line from replacing the pump. You can bleed it via the Schrader valve on the end of the intake manifold.
Old Dec 7, 2022 | 04:27 AM
Daftlad's Avatar
Daftlad
+1
Can also check fuel pressure there (gauge to Schrader valve) after the pump momentarily spools up with key turned to "ON" but not "START", should be 55 psi.
Old Dec 7, 2022 | 06:39 AM
RockC's Avatar
RockC
My 2nd hand experience is I came upon a tech working on a 993 Porsche which had sat just a couple of years outside in CA. The gasoline had turned very bad and the fuel tank and the in tank pump had to be replaced. I don't recall if the fuel lines were cleaned or replaced. Given how long they are and bent probably replaced. Nor do I recall if the injectors were cleaned or replaced. But the entire fuel system needed to be refreshed to allow the engine to start and run normally.
Sitting 7 years... I would hazard a guess the injectors are clogged. You can remove these and take them to a shop that can clean then flow test them to ensure they are all good and flow the same amount of fuel. Of you can replace them. (Some recommend new injectors be at least flow tested before installation.) But the fuel lines must be clear of any bad old fuel residue or you could clog the cleaned injectors or clog the new injectors.
pitdoidaoR53
Nov 29, 2022 10:20 PM
tanjg
May 28, 2021 09:52 AM
dinnanS_owner
Nov 14, 2019 02:04 PM
Eid2000
Oct 23, 2016 01:57 PM
MiniKar
Feb 17, 2013 02:15 PM
