Which side of headgasket goes to block?
Old Apr 28, 2022 | 02:53 PM
frankiev's Avatar
frankiev
Im going to change my head gasket in my r53 . There's no markings to indicate which side is up and which side go down ( to block ) . There's an obvious difference in the holes along one side vs the other . Could use some advice
Old Apr 28, 2022 | 03:36 PM
A383Wing's Avatar
A383Wing
should only go on one way with the dowel pins. Then the smaller holes in the gasket should line up with the holes in the block
Old Apr 28, 2022 | 04:28 PM
frankiev's Avatar
frankiev
Dowel lines up either way and the holes on the block are identical on the top and bottom however as you can see one side of the gasket has more holes . I found a video @18:53 that shows a block with the gasket so problem solved but strange the way the holes are different
https://m.youtube.com/watch?v=1cdcbK8bpVE
Brandon Fluharty
Sep 19, 2021 09:37 AM
sawdustman
Jul 31, 2016 08:59 AM
STLMINI
Classic Mini Talk
May 14, 2008 04:00 AM
kamikazy
Classic Mini Talk
Aug 4, 2007 09:37 AM
Jonauto
Jul 28, 2004 06:42 PM
