R50/53 Head gasket help
Old Sep 19, 2021 | 06:24 AM
Brandon Fluharty's Avatar
Brandon Fluharty
Head gasket help
I’m doing a head gasket swap on my bored out r53 that’s bored to 77.5 and both the head and block have been machined what head gasket and size should I get?
Old Sep 19, 2021 | 09:37 AM
BlwnAway's Avatar
BlwnAway
A little more info would be helpful.
- How much was cut from the Head
- How much was cut from the Block
But... In general... If you've taken material from both the Head and the Block, you may want to consider the thicker of your options, if nothing more than to counter balance any increase in compression from the two operations. This will minimise any chance of the ECU not adapting well to any increase in compression, plus possible extra heat created in the combustion chamber from any increase in compression. (Esp since our Head castings are notorious for heat stress cracking)
CSP
Apr 29, 2017 05:33 PM
mini2super
Apr 27, 2016 01:59 PM
Beecher
Jan 9, 2008 11:56 AM
kamikazy
Classic Mini Talk
Aug 4, 2007 09:37 AM
Jonauto
Jul 28, 2004 06:42 PM
