oil light came on at idle , car died ,now won't crank
Old Mar 30, 2022 | 07:59 AM
frankiev's Avatar
frankiev
Just finished a headgasket and on a test drive the oil light statted comming on at idle .Like a dummy I tried to make it home . The engine shut off suddenly and wont turn over . Battery is good . Did i just lock up my engine . Any ideas on why no oil pressure
Old Mar 30, 2022 | 09:39 AM
frankiev's Avatar
frankiev
Engine is definetly seized . Now what ?
Old Mar 30, 2022 | 01:02 PM
frankiev's Avatar
frankiev
No one? . How can I check what siezed. ?
Old Mar 30, 2022 | 01:46 PM
shrevemini's Avatar
shrevemini
Top Answer: 1
Remove the skirt on the passenger side. Get a socket that’s fits the crank bolt an try turning clockwise an see if you can turn over engine. Easier if plugs are removed.
Old Mar 30, 2022 | 02:19 PM
frankiev's Avatar
frankiev
First thing I did when I got it home . Locked up solid . Other than the low oil light at idle there was no knocking sound before it locked up . I'll pull the belt tomorrow and recheck the crank , maybe I'll get lucky . If it's toast isn't better to get a remann or just a used one . Anything else I should do to see what's up internally
Old Mar 30, 2022 | 02:51 PM
shrevemini's Avatar
shrevemini
Top Answer: 1
Your call. A lot cheaper fine a decent used one.
Do what work did you do to the engine?
You may get lucky by removing the belt.
Did you pull the plugs when you tried to turn over?
Old Mar 30, 2022 | 04:58 PM
frankiev's Avatar
frankiev
Tomorrow I'll pull the plugs and remove the belt. I replaced the head and head gasket also the timing chain and guides . I had the front cover off for a few days waiting for parts which leaves part of the oil pan exposed . when they cut the grass they blow the leaves and stuff away and I'm wondering if something was blown into the oil pan and clogged the pickup . The car ran perfectly for a out 15min before the light came on
Old Mar 30, 2022 | 08:49 PM
shrevemini's Avatar
shrevemini
Top Answer: 1
I bet they blew crap into your oil pan. There is a small opening just below the crank when the timing cover is off. Not good.
Old Apr 1, 2022 | 07:11 AM
frankiev's Avatar
frankiev
Engine is done . I pulled the oil filter and it's full of metal . Obviously the bottom end is done but is the head salvageable
Old Apr 1, 2022 | 12:34 PM
shrevemini's Avatar
shrevemini
Top Answer: 1
Wow that sucks.
Old Apr 1, 2022 | 01:33 PM
frankiev's Avatar
frankiev
If i had the cash id buy a long blick from Way. I see some for 2k or so on ebay. Have to thnk about what to do
Old Apr 1, 2022 | 01:58 PM
shrevemini's Avatar
shrevemini
Top Answer: 1
Look at car-part.com
should be able to find one there at a good price.
Old Apr 1, 2022 | 03:37 PM
frankiev's Avatar
frankiev
Will do .. thanks
Old Apr 3, 2022 | 01:25 PM
jjcsnlynn's Avatar
jjcsnlynn
To determine if the head is salvageable pull the cam caps off and see if there is scoring on the cam and or cam bearing surface. Since the engine starved of oil you may have damaged the cam and cam bearing surfaces. They do not have replaceable cam bearings. The head material is the bearing.
Old Apr 3, 2022 | 03:11 PM
frankiev's Avatar
frankiev
Provided the head checks out I'm thinking about possibly rebuilding the block. I've never done that before buy I'm sure I could if I tried. Can someone whos done this give me some advice on what i might need in parts or even wether i shouldnt do it
MINI Gunner
17
Jul 29, 2020 12:44 PM
CarlF
Apr 28, 2019 03:22 PM
todoubled
Sep 15, 2008 06:44 PM
MrCooperS
Apr 16, 2008 02:44 PM
tubwreck
Jun 5, 2006 10:10 AM
