Exhaust manifold removal
Old Feb 14, 2022 | 02:04 PM
cooper48's Avatar
cooper48
To all those who have done this: Is it possible to remove the stock exhaust manifold thru the top once disconnected. I need to replace the gaskets on the oil cooler and it sure looks simpler with the manifold removed. Or, is replacing the oil cooler gaskets easier than it looks?
Old Feb 14, 2022 | 03:32 PM
shrevemini's Avatar
shrevemini
Top Answer: 1
You can. But it an *** job to do.
Old Feb 14, 2022 | 06:46 PM
jjcsnlynn's Avatar
jjcsnlynn
Much easier to do oil cooler when the manifold is out. There are 6 or eight 10mm bolts holding the manifold on. Make sure you get the gasket before it falls down on the starter. Oh, disconnect the battery first. I remember it only coming out one way so be patient and try it several angles unti it comes out. It’s a tight fit.
you might be able to tie it to the side and get enough space.
oh, if you have the manifold cover on, that bolt that holds it on goes in at an angle or something weird. I find that the hardest part of the job.
There should be some videos on you tube.
Old Feb 14, 2022 | 06:57 PM
dmath's Avatar
dmath
I did the oil cooler gaskets through the right wheel well with the exhaust manifold in place. It's not difficult but is a little uncomfortable.
Old Feb 14, 2022 | 07:42 PM
ssoliman's Avatar
ssoliman
Bentley and TIS say though the right wheel well. I’ve not done it yet tho
durantson
Mar 29, 2020 03:49 AM
Red Robin
Sep 8, 2019 05:09 PM
AzBluesman1962
R57 :: Cabrio Talk (2009+)
Jul 25, 2018 03:06 PM
one73ronin
Jan 22, 2017 09:14 PM
B.Mank
Jun 16, 2015 04:55 AM
