2007 coolant sensor question
Old Feb 1, 2021 | 06:00 PM
ansan12001's Avatar
ansan12001
I changed the brittle female connector from harness to coolant temp sensor on 2007 N12 manual. I forgot to mark which wire goes on which side on the connector. They are white and yellow. Are the wires interchangable? Does anyone have a picture to illustrate where the wires go in relation to the sensor connector? I looked online but could not find anything. Please see pic of how i reinstalled the wires, i hope its right! Thank you
Old Feb 5, 2021 | 10:17 AM
mrbean's Avatar
mrbean
The DME measures the ohms of the sensor to determine temperature. So it shouldn't make a difference if the wires are reversed.
For what it's worth, the yellow goes to pin #1 and the white goes to pin #2. If you unplug it and look at the inside of the connector it will sometimes have them labeled.
GBugg
Jun 4, 2023 03:16 PM
Austinbe
Aug 22, 2020 06:03 AM
Austonpop
Jun 19, 2019 08:56 PM
kinger62
Mar 13, 2016 06:33 PM
randers51
R58 :: Coupé Talk (2012+)
16
Oct 9, 2012 01:30 PM
