Growl / Roar coming from '05 R52 when the top is down
Old Dec 16, 2020 | 02:16 PM
Cobre's Avatar
Cobre
I just bought a used 2005 Mini Cooper S convertible as a project car. It has a couple issues, including ABS and DSC lights, and the horn and passenger airbag not being connected.
I'm wanting to start work on it by fixing a low growl/roar that seems to be coming from the back, maybe passenger side but I'm not sure.
How should I go about diagnosing it? I'd rather not take it to a shop if at all possible. So far the biggest possibility in my mind is a bearing going out. Would this possibly be the issue?
Edit: Forgot to say that it seems to pretty much go away with the top down...would this just be road noise?
Old Dec 17, 2020 | 06:49 PM
jjcsnlynn's Avatar
jjcsnlynn
How many miles? Sounds like a bad wheel bearing. They are pretty easy to change if you have a variety of tools.
Old Dec 18, 2020 | 05:48 AM
Cobre's Avatar
Cobre
haha...160,000 miles. How should i test to confirm it’s a bearing?
Edit: Also is a bearing something that we could pick up from a local auto parts store, or should we get something special online?
Old Dec 18, 2020 | 07:38 AM
jjcsnlynn's Avatar
jjcsnlynn
There are a couple ways of checking a bearing. 1) look in the back and if you see rust dust from there the bearing rollers are it’s bad 2) use a stethoscope to listen for grinding as you turn it slowly. 3) pull tire and rotate the hub. It should have a little resistance and turn smoothly. If hard to tuen, choppy or spins freely with no resistance its bad.
You can get them from autoparts or rockauto. But you’ll want the bearing and hub combo. Its just 4 bolts to remove the rear hubs.
Old Dec 18, 2020 | 07:42 AM
Cobre's Avatar
Cobre
thanks, I’ll check it out whenever I get a chance!
mgbowser
Nov 30, 2009 07:02 AM
D3m0N
Aug 28, 2007 11:14 AM
mkwabena75
Cooper (non S)
17
Sep 11, 2006 12:34 PM
carlj
Tires, Wheels, & Brakes
Feb 23, 2006 05:59 AM
Flash
Aug 27, 2003 06:39 PM
