R56S New starting issue
Old Nov 6, 2020 | 03:05 AM
Ray B.'s Avatar
Ray B.
Hi everyone,
Having a new issue with the 2009 Cooper s over the past week or so. On a cold start, the car will start fine, then immediately die. Start again and it’s good, like nothing happened. No CEL. Hot starts seem to be a non issue.
This morning was the first time it took 3 attempts to get going. Normal driving the engine is very strong and returning around 32mpg.
Any thoughts?
Old Nov 9, 2020 | 02:21 AM
Ray B.'s Avatar
Ray B.
Update, finally a CEL misfire cylinders 2 and 4. Spark plugs maybe?
Old Nov 10, 2020 | 06:12 AM
takrdown's Avatar
takrdown
I'm not a mechanic so please take what I say with a grain of salt, but when was the last time you change the plugs? I would start there because it's the cheapest and easiest problem to fix and then go to coils. Swap the 1 and 3 cylinders plugs with the 2 and 4 and see if the problem moves. It is very odd that everything is normal and then it just dies.
Old Nov 10, 2020 | 04:52 PM
Ray B.'s Avatar
Ray B.
Replaced the plugs today. So we will see what happens tomorrow.
Old Nov 19, 2020 | 09:05 AM
thefarside's Avatar
thefarside
The cold start issue sounds like the HPFP is starting to die. Get a code reader that can monitor fuel pressure - check fuel pressure while you start. Idle pressure should be in the neighborhood of 700 psi (IIRC). Tank pump puts out around 60 psi (FYI).
Old Nov 20, 2020 | 04:53 PM
AZdsrt's Avatar
AZdsrt
Could also be time to have the exhaust valves walnut blasted.
Old Nov 20, 2020 | 10:39 PM
cpmetz's Avatar
cpmetz
Intake valves need blasting, not the exhaust valves.
genik
Oct 13, 2021 12:01 AM
vazdom
Nov 15, 2020 09:25 AM
Mr.Rauscher
Aug 22, 2014 08:34 AM
stecz
Jun 17, 2007 06:09 PM
MyMiniME
Nov 26, 2006 04:18 PM
