NEED HELP ID'ing this part
Old Jul 16, 2020 | 08:29 AM
cincy10s's Avatar
cincy10s
Hi everyone,
I have a 2010 Mini that isn't holding any coolant. When I pour coolant into reservoir, there is a hose that seems to be going from coolant reservoir to this part, but pours out underneath the car, I was able to blindly get pics of the broken part attached to the hose, from placing my phone underneath the car on the drivers side of the car. What is the part where this hose broke off from?
Any help you can give is GREATLY APPRECIATED.
Thank you in advance
Hose with pinch clamp broken off part
Old Jul 16, 2020 | 08:13 PM
squawSkiBum's Avatar
squawSkiBum
Moderator
Looks like one of the couplings to the auxiliary water pump broke. This pump runs after engine shutdown to circulate coolant through the turbo. Check out realoem.com to find the part number, then visit one of our forum vendors to order the replacement.
Old Jul 17, 2020 | 05:41 AM
Jason Cornelius's Avatar
Jason Cornelius
Welcome, are you in the Cincinnati area? If so I recommend ECS tuning for parts, if in stock, you should have it when 2 to 3 days. I’m over in Anderson, if you are in Cincinnati, and can come help turn a wrench if you need it.
Old Jul 17, 2020 | 05:56 AM
Yep aux water pump, OEM pump, 11537630368 and the updated part.
Thanks for the mention, it is here: https://www.ecstuning.com/b-genuine-...p/11537630368/
Old Jul 17, 2020 | 06:00 AM
Jason Cornelius
No problem, I’ve almost drove up there to pick up parts, 8 hrs round trip in the mini would be nothing, I’m sure there is plenty of room to cut that time down.
tdh1971
Jul 8, 2020 05:40 AM
Aindrid
Mar 20, 2020 08:15 AM
Lex2008
Jan 22, 2019 05:12 AM
X757XVeritas
Mar 4, 2016 08:56 AM
fourblades
Oct 8, 2013 09:44 PM
