DME Codes after Head Swap / Timing Belt Change
Old May 19, 2020 | 02:05 PM
Andernamen's Avatar
Andernamen
I have a 2011 base and replaced the head with another used head. I have two persistent codes that will not go away, P0011 and P0343. Both relate to the Camshafts/Timing. You tube videos indicated that if I do not clear the "Adaptations" I would get codes. I am guessing these are the codes? Considering purchasing the Creator C110 tool to clear the adaptations. Has anyone else experienced this after changing the head? I am pretty sure I set the timing correctly, any suggestions on how to check? Car runs, just kind of stumbles shortly after start up and seems sluggish at the lower speeds. Never driven the car before replacing the head, so not sure how it is supposed to feel..
Xjsf28
Dec 17, 2019 10:48 AM
SevillianSTS
Nov 1, 2019 07:44 AM
christanaa
Nov 10, 2018 05:57 PM
gum
Oct 9, 2018 04:11 PM
edognight
Oct 7, 2017 02:58 PM
