Creaking sound when turning at slow speeds...
Old Apr 25, 2020 | 08:16 PM
lordenco's Avatar
lordenco
I have a 2006 mini cooper S, When i turn steering wheel at very slow speed or parked, it makes a crack noise. It makes the sound even if the car is turned off. It is a creaking-type of sound coming from under hood. It happens when driving slowly and turning or turning the wheel - even a tiny bit - while the car isn't moving. ive attach pictures of strut mounts, I heard it may be this. please let know what this can be!!!
Old Apr 28, 2020 | 08:59 PM
ssoliman's Avatar
ssoliman
Yes sounds like strut mounts.
are they after market mounts?
i had a set of after market mounts that made the noise you’re describing.
a video might help. Hard to convey a sound through text...
Old Apr 29, 2020 | 12:21 AM
RB-MINI's Avatar
RB-MINI
It could also be the u joints or bushing/bearing on the steering column. There are a few threads you can find on the forum.
https://www.northamericanmotoring.co...ng-column.html
Old Apr 29, 2020 | 07:21 PM
lordenco's Avatar
lordenco
here is the link to the video I made.
Old May 2, 2020 | 08:52 AM
ssoliman's Avatar
ssoliman
Originally Posted by lordenco
https://www.youtube.com/watch?v=S0s-7NxwLAw
does sound like something in the strut assembly. Sounds like it happens when changing steering direction only. Am I hearing that right?
Is ur mini stock steering / suspension?
mine was more of a “dong” sound from the springs and a “creaking” sound from the mounts...was not stock
sounds like something is loose. Get it up on stands, wheels off, and do a visual while someone turns the steering...
Old May 4, 2020 | 10:19 PM
mr.r50's Avatar
mr.r50
Strut mount and or sway bar endlinks , had the same noise, when i lowered my car and didn’t replaced those two things
Old May 9, 2020 | 04:21 PM
ghostwrench's Avatar
ghostwrench
I'm going with strut mounts. My car did it a few years ago, I replaced them with parts from the dealer and the noise went away. It's back now.
I'm buying my next set from fcpeuro for the lifetime warranty.
I just replaced my front swaybar links for knocking noise going over bumps so now it's just that awful creaking noise I'll have to deal with.
Old Aug 8, 2020 | 08:31 AM
GearheadS's Avatar
GearheadS
Lordenco, did you ever fix this? My 05 has had the creaking for years and thousands of miles, not really getting worse so I ignore it, but yet slightly annoying. Don't think it's the strut mounts. Thx!
davidg5700
Aug 10, 2020 11:59 AM
evilness
Apr 25, 2011 09:13 AM
macthorp
Mar 27, 2011 08:31 PM
greatgro
Sep 16, 2007 09:55 AM
RaiderZA
Off-Topic :: Autos
14
Mar 30, 2005 06:30 AM
