EML light flashing while shifting gears/ How durable are these cars?
Old Jan 30, 2020 | 07:50 PM
imaslowdriver's Avatar
imaslowdriver
Lucky for me, there's quite a few windy roads in my area , and I make the most of them. Minis don't have much power so uphill I'm pretty much to the floor always for 10-15 mins, and I run the gears till redline. Although I only go up these roads once every one or two weeks, I feel like I'm being almost abusive revving it that high and especially for example downshifting into second from third at 50+ mph to get more power. I know these cars aren't Hondas, but how much can this car handle? I understand hard driving will inevitably make parts wear faster, but is the car built to take it? I do wait till the engine is warm before any hard driving, and I keep it below the red. Also, sometimes I've noticed when shifting and accelerating hard, the EML light on the speedometer flashes very quickly for maybe less than half a second. Is this anything I should be worrying about? It doesn't happen with normal driving, or even merging onto the freeway. Only when I'm full throttle and running it till redline.
Old Jan 31, 2020 | 07:14 AM
Andy_S's Avatar
Andy_S
When you put your 15% pulley on, did you also put on colder spark plugs as recommended?
Any other mods?
Old Jan 31, 2020 | 01:35 PM
imaslowdriver
Yes, I did, I'm using the JCW plugs, and I don't have any other mods other than the one ball mod, but the light was flashing even before I did that. I don't remember if this started happening after I did the pulley, the car seems to run fine though.
Old Jan 31, 2020 | 03:42 PM
MiniKar's Avatar
MiniKar
Call Way, at Way Motor Works. Get this thoughts. 770-234-9965
Old Feb 1, 2020 | 06:39 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
It could be the sign of a failing crank pulley as they all are going to fail. Go with the ATI damper when it does.
https://www.waymotorworks.com/super-...ulley-r53.html
Kinickie
Dec 10, 2009 12:10 PM
Guest
Mar 24, 2007 02:36 PM
boognish
Sep 6, 2006 08:48 AM
ball7068
Jan 30, 2004 07:56 AM
lukee
Mar 24, 2003 10:25 AM
