R53: oil pan crazed
Old Jan 17, 2020 | 02:32 PM
jjcsnlynn's Avatar
jjcsnlynn
R53: oil pan crazed
Have the engine out for a burnt valve and found the oil pan crazed pretty bad. Had an bad motor here to and it’s the same way.
Is this normal?
is this ok to use?
Recommendations on replacements?
Old Jan 17, 2020 | 04:32 PM
OCR's Avatar
OCR
Yep, normal. I've got three, all look the same as yours.
Just casting flaws.
Clean well and us as is.
OR... you can go over it with a small, fine grit disk sander (in a hand drill, or air powered motor) and smooth the surface. Then again...clean well.
Mike
Old Jan 17, 2020 | 07:50 PM
JAB 67's Avatar
JAB 67
Looks just like mine at 160K. Nothing but Mobil 1, 5W-30, changed every 7,500 miles.
Old Jan 17, 2020 | 08:09 PM
jjcsnlynn's Avatar
jjcsnlynn
Cool. Thanks.
tej98
57
Nov 9, 2020 05:03 PM
Rich.Wolfson
16
Jan 28, 2020 02:58 AM
Stella11
Jan 31, 2019 07:01 PM
JJGreer
11
Jan 19, 2017 05:38 AM
enkymion
May 4, 2012 11:34 AM
