R55S- No Crank/No Start/Batt good
Old Dec 26, 2019 | 03:34 PM
WIPMini's Avatar
WIPMini
Hello,
I've read a lot of posts about No Crank/No Start issues on this site, but none seem to be helping this issue i'm having. First off, This is a 2011 S Clubman. I replaced the engine about 8 months ago and drove it 4000 miles no issues!. One Day I parked it for a few nights, came back to try and start it and it wouldn't budge. No crank, the starter did not sound like it was getting juice at all. Pulled the codes (Foxwell N510 Elite) got the CAS terminal 50 error no comm with Starter.. worked with RPM motorsport, learned the CAS isn't the problem it's likely a wiring issue between the CAS and the starter. Other codes that came up at the same time as the T50 error was No comm with Alternator (3861 and 385C). I've checked wires for continuity, everything seems fine. One thing I did notice that the last time the car did start it sounded like it labored more than usual (perhaps the alternator is toast). The battery is new and is good, keeps a solid charge. All of the instruments light up on the panel. It only seems like the problem resides in the starter circuit.
So my question is, What am I missing here?? Relay Terminal 15 (I01069 behind JB A4010) is one of my culprits but I'm really don't want to pull that Junction box out of there to test it if I can avoid it. I've checked all relays/fuses for any failures, all seem fine except I01068 (culprit 2) which works, but it's a little unusual because if i test it, the windshield wipers start going, the Airbag light illuminates on the dash and i'm sure a lot of other things are happening.
Any insight from the community is awesome. I've learned so much sense i started this project, but this little gremlin is kicking my butt
Best,
John
2011 Mini Cooper R55S
124000 mi on body/ 58000 on swapped N18 Engine
Stock otherwise
Old Dec 26, 2019 | 04:32 PM
texasmontego's Avatar
texasmontego
Did you pull the starter and have it checked at the local auto parts store?
Old Dec 26, 2019 | 09:11 PM
giorgos's Avatar
giorgos
What was the outcome of the issue in your thread about the starter not fitting?
How many is "a few nights"? Did you try jumper cables?
Old Dec 27, 2019 | 06:49 AM
WIPMini's Avatar
WIPMini
I didn't take the starter to the Parts store, but I did pull it and put 12V to it and everything worked. My local parts store doesn't have a the right hook ups for a Mini starter.
Old Dec 27, 2019 | 06:51 AM
WIPMini's Avatar
WIPMini
I replaced it with a different one and it worked. the Teeth count on the first one was off. it wouldn't grab the flywheel.
The car sat for two days before i tried starting it again. Yes I tried jumping the battery too
RocketUSA
21
Oct 14, 2019 10:23 AM
dieseldogpi
Dec 31, 2018 06:37 AM
2004minicooper
Feb 9, 2016 03:20 AM
MiNi_MaC
Jul 13, 2009 10:58 AM
Lolo
Feb 12, 2003 09:57 AM
