Tire Pressure indicator won't reset
Old Dec 8, 2019 | 07:03 AM
Cngizbleevng's Avatar
Cngizbleevng
A couple months ago we had the dashboard indicator pop up showing the left front tire needed more pressure.
I pumped it up (it was only a few PSI low), and almost immediately afterward, the indicator came back on showing all four tires needed air.
I now have them all slightly overpressurized and the indicator won't go away. I've checked with two separate pressure gauges and they are in agreement.
Will the indicator lamp come on when tires are overpressurized or only when they are under? How do I get rid of that distracting warning lamp?
Thanks for any help you can offer.
Old Dec 8, 2019 | 11:02 PM
giorgos's Avatar
giorgos
You don't mention in your post whether you reset the tyre pressure indicator.
Edit: Does your car have the old (i.e. depending on the ABS sensors) or the new style (actual pressure sensors in wheels) TPMS?
Old Dec 9, 2019 | 02:51 AM
mustangcruise's Avatar
mustangcruise
I've experienced the issue several years ago after putting too much air into the tires. I don't recall the exact amount that it triggered it but after letting air out and resetting all was well and no warning light.
Old Dec 9, 2019 | 08:21 PM
Cngizbleevng
I don't know. It's a 2010 model if that clarifies things. It seemed to me that in the past all I had to do was restore the proper pressure and the light went out. I don't remember having to reset anything inside the car.
Thanks for the suggestion. I'll try to release some air and see if things change.
Old Dec 9, 2019 | 08:37 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
Owner's manual and YouTube show reset process.
MiniSquirty
Jan 8, 2015 10:06 PM
greentea
Oct 10, 2014 10:29 AM
Darwin
R60/R61 Stock Problems/Issues
12
Oct 26, 2011 02:32 AM
krishnika
Tires, Wheels, & Brakes
Aug 31, 2010 01:19 PM
robn999
Jan 3, 2008 01:07 PM
