Need help running issues!!!
Old Nov 14, 2019 | 07:33 AM
Jeff k's Avatar
Jeff k
Hello, I’ve been directed here to the gurus of mini, I have an issue and I need help pinning it all down. I have a 2011 Mini Cooper countryman s all4 just rebuilt their motor. Had an issue with it wanting to start then die finally had multiple codes code come up. I could clear them and different ones would come back fixed the issue with a ground wire on the valve cover.
new issues
Alright new issue....
Codes I am getting
P16e7
P0324
P10ed
Po53a
Car was running fine then started all this.....
I drove the car out of the shop it was running for about 20 mins dueling quietly now I have no gas pedal can’t drive it but when it’s idle if it sounds alright aside from the noisy valvetrain. I checked the timing on everything and compression again and it is all spot on!
I am very very lost here because the only different I can find between now and before the rebuild is is running on all 4 cylinders..
please help thanks in advance!
Old May 27, 2020 | 11:56 PM
Dan_in_WA's Avatar
Dan_in_WA
Did you ever resolve this? Sorry I’m late to the party.
Old May 28, 2020 | 06:17 AM
Jeff k's Avatar
Jeff k
hey soul from my understanding the dual Vinos needs to be re-adapted after an engine overhaul like what I did. I still have not taken it to the dealership to get that done but some of the issues I have had to cause a lot of codes ended up being faulty sensors like the oil pressure sensor the gas pedal the fuel rail pressure sensor I think that was it every time I fixed one item a new item surfaced that was bad and needed replacing
Old Jun 7, 2020 | 11:30 PM
Dan_in_WA's Avatar
Dan_in_WA
I’m not certain on Minis, but on most cars if you disconnect the battery for about 30 minutes the memory is lost and the car will re-learn how to manage the engine.
Runs rough for a bit, and the engine stalling may happen too. But it saves you the expense of taking it to a dealership.
Old Jun 14, 2020 | 03:09 PM
Chernobyl's Avatar
Chernobyl
Unfortunately, this won't work. Engine adaptations for 2nd generation MINIs are stored in non-volatile memory -- which is not affected by disconnecting the battery power. The only way to reset the adaptations is via software through the OBD-II port.
Jeff k
R60/R61 Stock Problems/Issues
Nov 19, 2019 07:14 PM
hotrods70
Apr 30, 2016 10:01 PM
Jimbits
Dec 1, 2013 08:51 AM
effkay
Jul 12, 2013 04:06 PM
tominizer
Mar 7, 2011 04:31 AM
