Crank position sensor o-ring options
Old Oct 28, 2019 | 11:28 AM
ssoliman's Avatar
ssoliman
Guys I replaced the o-ring on my crank position sensor and now it’s leaking worse than before :/
When I pulled it off I noticed it had rtv on it. Cleaned it up completely and cleaned up the port on the engine as good as I could.
Is there a better o-ring option than stock? Or is there a technic to this that I might be missing?
Should rtv be used?
Old Oct 28, 2019 | 11:58 AM
gumbedamit's Avatar
gumbedamit
Should rtv be used?
I didn't see where you stated that you replaced it with a New OEM o-ring?
Make sure that you've cleaned off all the old o-ring. When I replaced mine, I didn't use RTV, no leaking.
Old Oct 28, 2019 | 04:41 PM
ssoliman's Avatar
ssoliman
Thanks for the reply, gumbedamit
I replaced it with a new stock o-ring. I’m going to verify the part, order a new one and give it another go.
The O-ring looked like it was too small for the application. Looked like it could be thicker.
Old Oct 29, 2019 | 02:00 PM
Eric_Rowland's Avatar
Eric_Rowland
That's strange. I replaced mine with OEM, cleaned up the leak toot-suite.
Old Oct 29, 2019 | 03:09 PM
ssoliman's Avatar
ssoliman
Yes sir. I ordered the wrong one...looked back at my order... :/
New one on the way. Wonder if I can get it on without front end maintenance mode? Gonna be tight
gknorr
Mar 30, 2016 11:05 AM
cw40342
Sep 3, 2014 03:35 PM
purplehaze05mcs
Jul 22, 2013 05:41 PM
JAB 67
Jun 24, 2011 01:04 PM
donjulio
Mar 28, 2011 06:59 PM
