R52 Soft Top pulls back not enough
Old Sep 7, 2019 | 02:55 PM
Elijah's Avatar
Elijah
Hello everyone!
Couple months ago I admitted that my soft top is not in proper position when open. It's "shelf" is a little bit forward and thus scratches the plastic of rolling bar. I saw similar problem here:
https://www.northamericanmotoring.co...correctly.html
But my problem is worse - both sides rub against the backseat headrest and it is causing the top to fray significantly :(
I dissasembled front motor and realigned the cables - they are in proper position - both sides are the same, locks work correctly, soft top opens and closes without other problems.
Is there any way to pull the "roof shelf" 1 cm back?
No gap at all :(
Old Oct 29, 2019 | 05:53 PM
Charles Roche's Avatar
Charles Roche
no answers yet? having the same problem with mine. ever have any luck with yours?
thx
chuck
Old Oct 30, 2019 | 07:26 AM
It needs adjusted, thats all. MINI dealerships can do it if you dont feel like you can do it. See that link above and post #5 on that link. Post #4 one person got it to adjust.
Old Oct 30, 2019 | 09:09 AM
Elijah's Avatar
Elijah
The sunroof parts (left and right sides) are adjusted perfectly. It seems that the whole roof construction needs to be adjusted. Or hall sensors positions are wrong
Old Oct 30, 2019 | 11:35 AM
ok, i just know when i had my r52 back in the day (2006), they could set the limits on the cables a hair back which is enough to clear that roll bars and trim.
Steffen.Johnson
36
Mar 11, 2015 07:31 AM
minicoop23
12
Aug 4, 2014 09:33 AM
B&D
Mar 23, 2007 06:49 PM
shankrabbit
41
Jun 25, 2006 11:20 AM
